Old 13th May 2021, 2:48 pm   #1
60 oldjohn
Default Lead Tin liquid solder.
Is there such an item as Lead / Tin Liquid solder? I have some SMD soldering to do. I have seen liquid solder that has a short shelf life it has to be stored at a low temperature and brought up to a high room temperature before opening.
I hope something is available that works and is simple to use at a reasonable price.
John.
My favourite text message "I'll be there in five minutes, if not read again"
60 oldjohn is offline
Old 13th May 2021, 3:01 pm   #2
Restoration73
Restoration73's Avatar
Default Re: Lead Tin liquid solder.
I think the term is "solder paste"
https://uk.farnell.com/search?st=solder%20paste
Restoration73 is offline
Old 13th May 2021, 3:22 pm   #3
60 oldjohn
Thanks for that, I did originally search for solder paste and got a lot of flux items.
Any makes better than others? anyone.
John.
Old 13th May 2021, 3:46 pm   #4
barrymagrec
The couple I have tried (can`t remember the make) both went thick and difficult to apply quite quickly but warming the board with a heat gun improved things considerably. Useful in some cases for multi pin devices but on the whole, more trouble than it`s worth.
Practice does improve results greatly though.
On the whole I tend to use 0.46mm solder and a small tipped iron.
barrymagrec is offline
Old 13th May 2021, 8:12 pm   #5
Keith956
Keith956's Avatar
I use Loctite solder paste from RS. Buy the smallest syringe and keep it in the fridge as it will go solid over time.
Keith956 is offline
