20th Mar 2021, 9:44 pm | #1201 |
Re: Non-working Commodore PET 3016
We have what look like good clock / clear input signals to both halves of UH1 but no apparent output from UH1, either part.
Could you just verify that UH1 pins 2 and 12 both have steady high states on them? Also look for any activity on UH1 pins 5 and 9. |
20th Mar 2021, 9:48 pm | #1202 |
From #1119 inputs to UH1 you should have activity on UH1-8 and UH1-6.
To be a little more certain please confirm pins 2, 4, 10 and 12 of UH1 are constant high. Then See if there is any activity on UH1-5 and UH1-9. |
20th Mar 2021, 9:59 pm | #1203 |
UH1/2 and UH1/12 both high - 5.3V.
UH1/5 - slight uptick measured as 0.6V on a meter, but no waves. UH1/9 goes high - 5.4V on the meter. Colin. |
20th Mar 2021, 10:01 pm | #1204 |
20th Mar 2021, 10:09 pm | #1205 |
I think its time to get the solder sucker going again.
Do you have a 74S74? It might also work with a 7474 or 74LS74, though the timing will be slightly different it would at lease confirm the 74S74 was faulty. |
20th Mar 2021, 10:11 pm | #1206 |
Are we thinking dud UH1? An awkward one, 74S74. Are they available? Must be a specific need for that type as they used 74LS74 elsewhere. Crossed with Mark.
I think Colin may have a 74LS74 already, but Commodore surely used an 'S' for a specific reason. |
20th Mar 2021, 10:12 pm | #1207 |
I bought one from post 807.
It's marked as SN74LS74AN. That be ok? Colin. |
20th Mar 2021, 10:17 pm | #1208 |
I would try the 74LS74AN, maybe try and get a 74S74 later. We’ll need to keep it in mind in case of any strange issues later.
Make sure its socketed. |
20th Mar 2021, 10:17 pm | #1209 |
Cricklewood have the 74S74 if I need that specifically?
Colin. |
20th Mar 2021, 10:18 pm | #1210 |
So - what's the difference between a 74S74 and a 74Ls74 then? What does the L mean?
Colin. |
20th Mar 2021, 10:19 pm | #1211 |
It should probably show different behaviour from the apparently dud original UH7, but best to try to source a proper replacement if possible. I'll have a look around and see if there are any historic instances of this having been replaced with other flavours. Bit of a long shot.
What's so exotic about the 'S' series? Slothie will know. If Cricklewood have the 74S74 I am beginning to think they must be PET parts specialists, so yes, if you can get one please do. |
20th Mar 2021, 10:25 pm | #1212 | |
Wikipedia description of the 74LS series which suggests that the difference between 74S and 74LS is lower switching speed in 74LS, traded for lower power consumption.
20th Mar 2021, 10:25 pm | #1213 | |
Ordered. Is there likely to be a problem if I pop a socket in and try the 74LS74 first?
Colin. Quote:
20th Mar 2021, 10:33 pm | #1214 |
As in a chain reaction in which all the other ICs burst into flames? Possibly not. Since the right IC is available, I personally would be Mr. super-patient and wait until it arrives, but you are free to do as you wish.
Ironically, when I gave you that short list of ICs to order just in case, I deliberately sidestepped that 74S74, hoping we wouldn't end up needing to find one. A while ago I joked that the alternative repair method would be just to re-chip the whole PCB. It's almost heading that way. I can't imagine how this could have ended up in this state with such a high and seemingly almost random chip mortality rate. |
20th Mar 2021, 10:36 pm | #1215 | |
I'll get the socket in tomorrow. Probably Tuesday before the new IC turns up.
I hope none of the duff chips have been due to my ham-fisted testing. I'm still determined though. Colin. Quote:
20th Mar 2021, 10:47 pm | #1216 |
I don't think you are responsible for anything which has happened here. The only thing we can definitely say is that the machine lived in a very damp environment for a long time, but I can't really imagine how that would cause such large scale chip death, I would usually expect that the hardware (tracks, vias) would be the first to suffer under those circumstances.
20th Mar 2021, 10:47 pm | #1217 |
The S series was 3 times as fast as LS (3nS delay vs 10nS, I think) but had 10 times the power consumption. There were other later series with different trade offs, like ALS (Advanced Low power Schottky). Maybe the high speed of S was needed in a specific location but ALS or AS are reasonable fits too if the LS doesn’t work.
20th Mar 2021, 10:50 pm | #1218 |
Thanks for the info. They obviously needed that quickness in this specific location. As the ever dependable Cricklewood seem to have the 74S, I think we may as well fit the real thing.
21st Mar 2021, 12:05 am | #1219 |
I suspect this pet had some overvoltage or static discharge that stopped it working before it went into storage.
For the 74LS74, I don’t think we need to worry about setup time as D is held high and there looks like plenty of recovery time from reset to clock. Propagation time from clock or reset to /Q could affect timing between RAS and CAS, which could be a reliability issue for the dynamic ram. I don’t think there is a risk of the 74LS74 causing any further damage. I’d be tempted to try it, but its not my pet. |
21st Mar 2021, 12:12 am | #1220 |
For the avoidance of doubt / fear, I don't think it will cause damage but it may cause misleading behaviour which could send us off on a wild goose chase, unnecessarily so when the right IC is actually available. If you want to try it, I'm quite happy to observe from a safe distance.
I did wonder if possibly the PSU has a mind of its own and likes to lash out every now and again - if possible maybe eventually put some high wattage 'just above rail voltage' zeners on the supply rails so that if the regulators do go doo-lally it won't do too much damage. |
