12th Mar 2021, 2:37 pm | #961 |
Re: Non-working Commodore PET 3016
Quite a lot to dissect here, I may not be able to give this due attention until this evening, unfortunately (anyone else, please pitch in).
12th Mar 2021, 3:08 pm | #962 | ||
Certainly there is a V4 ROM disassembly under your link but in this case what we'd need would be a disassembly of V2.
The results of your other measurements are quite interesting. This one: Quote:
However the state of UC7 (19) is less clear cut. I would expect that one to be programmed as an output and then turned on (high) to hold the cassette enable transistor Q6 on, thereby holding the cassette motor? driver pair Q5/Q4 off. UC7 / 19 is applying a high to Q6 to turn it on, but not a very convincing one at 2.7V. That might be the best it can manage into a resistive load of 1K + a transistor junction. Or it might be that pin 19 is still an input and is just floating high. This: Quote:
12th Mar 2021, 4:49 pm | #963 |
If you could check the write to video ram in a bit more detail just to confirm there is no write to ram attempt.
UF1-6 UA5-12 UA5-8 UF6-7 These should all show a burst of activity after reset, just want to confirm with the updated settings on the scope. |
12th Mar 2021, 4:57 pm | #964 |
OK - new UF9 now in place. Solid checkerboard symbols with the chip in place.
Colin. |
12th Mar 2021, 5:02 pm | #965 |
UF1-6 - I can see one wave/pulse before it settles back to a zero response after power on.
UA5-12 and UA5-8 and UF6-7 go straight to high and stay there. Colin. |
12th Mar 2021, 5:05 pm | #966 |
That's odd. With the old UF9 didn't you have a screen full of semicolons and subsequently reverse @ symbols? By the way, were they really displayed as mirror images do you think?
Alan Last edited by ajgriff; 12th Mar 2021 at 5:20 pm. Reason: Additions |
12th Mar 2021, 5:35 pm | #967 |
Actually, the checkerboard pattern is a better reflection of what was being presented to the inputs of UF9 - all ones (all high). The old UF9 was replaced, in part, because it obviously was not passing on that 11111111 to the character generator.
The question remains whether that 11111111 input to UF9 is coming from the RAMs or is being imposed on the SD... lines by the video databus buffers. |
12th Mar 2021, 5:37 pm | #968 |
12th Mar 2021, 6:28 pm | #969 |
I think Colin may possibly mean 'inverse' rather than 'reverse'? Black character on white (or green, I guess) background? Or do you really mean that the @ symbol was facing in the opposite direction to normal?
12th Mar 2021, 6:43 pm | #970 |
My inverse is your reverse - yes. Black on green.
Colin. |
12th Mar 2021, 6:53 pm | #971 |
I've just used an online disassembler to take a look at the first few bytes the 6502 should try to execute when it gets going.
The bytes at FFFC and FFFD (which I understand contain the jump-to-on-reset address) contain D1 FC and I'm also assuming that these are stored in address lowbyte, hibyte order so the first address the 6502 actually goes to is FCD1. This is what I see at FCD1 - on in UD9. Code:
FCD1 A2 FF LDX #$FF FCD3 9A TXS FCD4 D8 CLD FCD5 20 DE E1 JSR $E1DE FCD8 A9 89 LDA #$89 FCDA 85 94 STA $94 FCDC A9 C3 LDA #$C3 FCDE 85 95 STA $95 FCE0 A9 17 LDA #$17 FCE2 85 92 STA $92 FCE4 A9 FD LDA #$FD FCE6 85 93 STA $93 FCE8 A9 F7 LDA #$F7 FCEA 8D FA 03 STA $03FA FCED A9 E7 LDA #$E7 FCEF 8D FB 03 STA $03FB FCF2 58 CLI FCF3 AD 10 E8 LDA $E810 FCF6 30 03 BMI $FCFB FCF8 4C 11 FD JMP $FD11 FCFB 4C 16 E1 JMP $E116 FCFE 6C 94 00 JMP ($0094) For that to work, as Mark said earlier, there has to be working RAM so that the subroutine call can push the current program counter address onto the stack (in RAM) so that it can recover it and come back to this point afterwards. If there is a fault in main RAM, the initialisation could fall apart quite quickly. I do think this is the genuine reset-vector code because the first few bytes set the Stack pointer to the high end of zero-page ram and explicitly set the 'math mode' of the CPU which would otherwise be indeterminate. And then it's straight off into a JSR as soon as the stack is up and running. Last edited by SiriusHardware; 12th Mar 2021 at 7:05 pm. |
12th Mar 2021, 7:30 pm | #972 |
Just to clarify on this, without working ram the 6502 will still be able to execute the jsr and execute code at the target address, but it won’t be able to return to the correct address after that subroutine tries to return.
12th Mar 2021, 7:44 pm | #973 |
Is there a way to disable the dynamic ram to allow a static ram to be connected without cutting tracks?
Maybe possible to remove the dynamic ram data buffers and connect a 6264 type static ram on the external expansion. Anyone able to create a diagnostic rom that could exercise read and write to ram, without depending on ram working? Simple loop with write 0 to ram address 0, read ram address 0, write FF to ram address 0, read ram address 0 then repeat. |
12th Mar 2021, 7:55 pm | #974 | |
Is it possible to do this with an Arduino whilst the PET is powered off? or would each RAM chip have to be removed?
Colin. Quote:
12th Mar 2021, 8:00 pm | #975 |
Excuse the second interruption - I could not find any 3016 disassembly but there are some similarities in the start of the 4032 code listed halfway down (look for "Power-Up RESET Entry") this page:-http://www.vcfed.org/forum/archive/i...p/t-50793.html
You might be able to identify some of the addresses from this - and check the "diagnostics line"?
George |
12th Mar 2021, 8:05 pm | #976 | |
Suggestion, every time the test code writes to RAM and reads back the same data it keeps going through all of zero page (0x0000-0x00FF) round and round. If it writes to RAM and fails to read back the same data then have it intentionally run into a KIL instruction. Continued activity on A0 etc = zero page RAM is OK Activity stopped on A0 etc = zero page RAM is not OK. This is the simplest way I can think of to indicate 'pass' or 'fail' without trying to use any hardware which we don't know works yet. Even so, we could also include a bit of code which will try to wiggle one of the I/O IC port pins each time around the loop so if we can see that happening we can definitely then say the code is being executed. Of course this also means making an adaptor to allow a common EPROM or EEPROM to plug into UD9 position. I'll have a look at the subroutine in the Edit PROM (which the initial code jumps to almost straight away) to see how that unfolds. What I really want to find is some definite action which the firmware performs very early on, and then look for some hardware indication that that has actually happened. It would be surprising if the 6520, 6522 etc are not initialised very early on. |
12th Mar 2021, 8:13 pm | #977 |
Colin, yes, in theory you can take the CPU out and have your Arduino generate all the signals required to access, write to and read from the RAM and it would be a pretty cool thing to try, but with the memory being dynamic RAM that is apt to be more complicated than it would be if the RAM was static RAM. It would take quite a bit of thought about how to do it.
George, acknowledged, from the sound of it that disassembly is the one of the V4 PROMs which I have also found elsewhere and you are right, if both the V2 and V4 PROMs can run in this hardware then any device I/O addresses referred to in the V4 disassembly should also apply in the V2 code as well. Keep the ideas and observations coming, don't be shy. |
12th Mar 2021, 8:31 pm | #978 | |
If you continuously cycle the dynamic ram it probably doesn’t need to be refreshed, we’ll need to consider what to do with all the other control signals the 6502 generates, but I think a lot of them could be held inactive. This would stop the pet generating video timing, but still test the video ram and identify if the buffers or the ram are the issue. Edit: this would be used with the pet turned on, but with the 6502 replaced by the arduino. |
12th Mar 2021, 8:47 pm | #979 |
Yep, that's the idea. Can I let you work on the detail of what needs to be held in what state? If we are just testing zero page to begin with A8-A15 could be strapped to 0V, possibly. We could expand it to an 'all RAM' test later.
Ref: The need for refresh or not, bear in mind that the Arduino system has a very clunky way of accessing I/O port pins, namely one bit at a time, so if you have a 16-bit address that you want to output you have to scan the variable holding it and output each individual bit to an I/O pin. That makes it a lot slower than you might originally envisage. Of course you can abandon the Arduino sphere, go direct to the ports at hardware level and access the ports as 8-bit wide parallel ports but that would all be very new to me, while I've done that with PICs and 8051-series microcontrollers I have not attempted to use Arduino boards at native 'bare metal' level. Despite all the above, I think a better initial move might be to try to get the 6502 itself to run simple test code. We need to know, one way or another, whether the basic CPU subsystem (CPU reads code from PROM : CPU executes code) is working. |
12th Mar 2021, 9:13 pm | #980 |
Would it be easier for me to think of selectively replacing the RAM chips then? Is there any way to test them at all?
Colin. |
