24th Nov 2020, 11:35 am | #1 |
Pye radio date
hello all,
Just got this Pye radio and I think its just pre war. Any one confirm this ? Anything I should watch out for when restoring? |
24th Nov 2020, 11:39 am | #2 |
Re: Pye radio date
Looks like a PYE QAC2 (there are 2 versions so you will need check which it is)
https://www.radiomuseum.org/r/pye_qac2_2.html So 1937 Just the usual pre war radio stuff crumbling wiring non recoverable electrolytics leaky caps and high value resistors. Before you do anything else check the LS field coil mains and output transformers. Cheers Mike T
Invisible airwaves crackle with life or at least they used to Mike T BVWS member. www.cossor.co.uk Last edited by Cobaltblue; 24th Nov 2020 at 11:41 am. Reason: added a bit |
24th Nov 2020, 12:01 pm | #3 |
Re: Pye radio date
Nice looking radio and in good condition.
If all the transformer windings check out with sensible continuity readings. Reform or more probably replace the smoothing caps and change the .003uF audio coupling cap that connects to the grid of the OP valve. Then its a matter of taking it stage by stage, checking voltages and so on. Mike Last edited by crackle; 24th Nov 2020 at 12:07 pm. |
25th Nov 2020, 11:41 am | #4 |
Re: Pye radio date
Killed two birds with one stone.
Another tip find many years ago and I was never certain exactly which model it is. I also have the radiogram version that I overhauled decades ago and it gives a good account of itself. Strangely I have never powered up this table model. Pye rarely printed model numbers on the backs or internals of their products until around 1950. Your example looks to be in nice condition and if the radiogram version is anything to go by, should be a straightforward restoration. Hope it turns out OK. John. |
25th Nov 2020, 12:18 pm | #5 |
Re: Pye radio date
A very nice set, as John has said, should be a very straightforward restoration.
Nice to have the original guarantee card, odd that it was never filled in & returned to Pye. Mark |
25th Nov 2020, 2:01 pm | #6 |
Re: Pye radio date
25th Nov 2020, 2:42 pm | #7 |
Re: Pye radio date
Looks exactly like my Pye Q.AC2, circa 1937. No short wave band.
25th Nov 2020, 4:03 pm | #8 |
Re: Pye radio date
Very similar to my Q.AC38. Nice sound for quite a small radio.
Clive |
25th Nov 2020, 5:36 pm | #9 |
Re: Pye radio date
Snap! same as my QPAC and thats also 1937
Oh I've had that for years dear!! |
