20th Nov 2020, 1:35 pm | #1 |
New Member
Inherited vintage radio (Sobell 719C)
Hi
Let me start by saying I know almost nothing about vintage radios. We inherited this fine specimen some years ago, it lights up but no sound at all comes out. Firstly does anyone know what it is (inside is a pencilled label saying 719). Any ideas on if it is easily fixed and lastly whether it is worth tuppence or 10/6d Michael |
20th Nov 2020, 2:27 pm | #2 |
Re: Inherited vintage radio
Hi and welcome,
It's a Sobell 719C. https://www.vintage-radio.net/forum/...d.php?t=148324 Not worth a fortune by any means, floor-standing radios are a minority interest, but it's a good one and deserves a home - if you're not keen on keeping it I expect someone here would be interested. If you haven't plugged it in lately, don't, as a lot of damage could result. Repair may not take more than a couple of cheap components, restoration for peak performance and regular use would need more but still probably nothing very expensive. Paul |
20th Nov 2020, 2:37 pm | #3 |
It's in very good cosmetic condition.
20th Nov 2020, 4:33 pm | #4 |
Re: Inherited vintage radio (Sobell 719C)
For my interest, why was that created so large? Was it to match the speaker for the best sound quality or volume? Or was it a bit of status 'my one is bigger than your one', sort of thing?
20th Nov 2020, 4:43 pm | #5 |
Partly for status.
But when a loudspeaker creates a positive pressure wave in front of it, it makes a negative wave behind it. One function of the cabinet is to block flow of air between the front and rear of the speaker. The longer it makes the path around, the better lower frequency sounds are created, so the larger cabinet enhances bass sounds which would have otherwise been lost. David
20th Nov 2020, 4:46 pm | #6 |
Known as a Console Radio, they were quite popular at one time. With no TV or Internet, radio was the height of domestic technology back then. That's not a particularly big one, my Grandparents' Pennine was bigger than that one appears to be.
20th Nov 2020, 6:05 pm | #7 |
America produced many extremely complex console radios, some with 20 or 30 valves and multiple loudspeakers: the UK not so much, 15 valves was pretty much the upper limit here and many console sets were versions of standard table models just using 4 or 5 valves. The chassis can look a little lost in the interior space of some of those. There's a table version of your set, but it's a big beast -
https://www.radiomuseum.org/r/sobell_717.html I'm quite taken with consoles, the improved bass response is welcome as is not having to find another substantial piece of furniture to stand them on |
20th Nov 2020, 6:49 pm | #8 |
With two IF stages and push pull PEN45s with cathode feedback a la Quad II it should give a good account of itself in going order.
20th Nov 2020, 9:46 pm | #9 |
Have you connected an aerial to it? These need an external aerial.
I was so upset that I cried all the way to the chip shop. |
21st Nov 2020, 5:46 pm | #10 |
That is lovely! My kind of radio, sadly not that valuable, but should be saved as there cant be many of them left.
It probably isn't too difficult to fix if you have some knowledge, but don't fiddle with it if you don't.
Clive |
21st Nov 2020, 7:12 pm | #11 | |
23rd Nov 2020, 3:12 pm | #12 | |
Edward. |
