Old 12th Oct 2020, 7:27 pm   #21
CrazySwede
CrazySwede's Avatar
Default Re: Trying to revive a Goodmans One Ten receiver
Sorry for slow updating on this. Anyhoo: have dumped another half a can of contact cleaner into the switches but no result.
Tried connecting a signal to tape input but not a sound.
Measured the IC:s as suggested and got:
IC 3
Pin 14: 13,7v
Pin 7: 1,3v
IC 2
Pin 14: 13,6v
Pin 7: 1,3v
This looks not right, right?
Should be +14,3v and -14,3v if I interpret the schematic right?
What now?
Thanks in advance for suggestions for further troubleshooting!
CrazySwede is offline
Old 12th Oct 2020, 7:44 pm   #22
tony brady
check the voltage on VT41. the negative voltage on IC2 & 3 is not correct.
the +13.6V is close enough on pin 14
tony brady is offline
Old 12th Oct 2020, 7:59 pm   #23
CrazySwede
CrazySwede's Avatar
Tony, thank you so much for advice and taking time to help this poor Swede out. Much appreciated! I have closed shop for tonight but will try to get that VT41 voltage checked tomorrow.
Old 13th Oct 2020, 12:29 am   #24
jamesperrett
As Tony says, check VT41 and, if there are no volts on the collector or emitter, check the voltages on R169 and its associated smoothing capacitor. If the voltages on VT41 look correct you need to look for a broken connection between VT41 and the IC's.
jamesperrett is offline
Old 13th Oct 2020, 7:33 pm   #25
CrazySwede
CrazySwede's Avatar
Hi!
Here's some voltages. Hope I got it right ...
The transistor measurements are after markings on the PCB.
VT41
E: -1.33
B: -14,3
C: -25.6
VT40
E: 13.6
B: 14.3
C: 23.6
R169
-25.6
C151
24.7
Ç152
-25.6
R167
-18.6
- 14.6
Measured both sides.
So looks like the E-voltace on VT41 is way off or is my thinking off?
Old 13th Oct 2020, 7:59 pm   #26
tony brady
it looks like VT41 is faulty and should be replaced
Old 13th Oct 2020, 9:25 pm   #27
CrazySwede
CrazySwede's Avatar
Thanks! Good have a course of action. According to the parts list in the service manual it's an e5359 transistor. Have done a quick search but failed to find one for sale. Is it no longer manufactured? Any similar transistor that can replace it?
Old 13th Oct 2020, 9:52 pm   #28
tony brady
I think that's a Thorn part number. I don't know what the direct equivalent actually was - what package is it? TO92?
I would fit something like a ZTX753 which are easy to get and more than enough to do the job. just be careful with the pin outs
Old 13th Oct 2020, 11:30 pm   #29
Chris55000
Hi!
Looking at the pinout at the bottom of the power–supply circuit, VT40 and VT41, are plastic transistors of the TO92b type, and you'll find the BC639 (npn, VT40) and BC640 (PNP, VT41) will be ideal to replace the E5358 (npn) and the E5359 (PNP), and will fit the board exactly the same orientation as the original devices.
Please be aware tho', that simple emitter–follower series stabilisers of this type are NOT short–circuit proof, so take great care not to accidentally short–circuit the ±14V lines whilst making tests!
If either transistor fails immediately after replacing it, there could be an i.c. or decoupling capacitor(s) downstream of VT40 or VT41 defective!
Chris Williams
Chris55000 is offline
Old 14th Oct 2020, 5:43 am   #30
CrazySwede
CrazySwede's Avatar
Thanks for clearing this up. Yup, BC639 and BC640 seems to be easy to find. Since I will be paying shipment I could just as well order more stuff. Do you see any other suspects that I could add to the shopping list to have at hand if the VT41 is not the problem?
Old 19th Oct 2020, 7:18 pm   #31
CrazySwede
CrazySwede's Avatar
Hi, I'm back.
Finally got the replacement transistor I ordered.
So took a deep breath, trying not to think of how long it was since the last time I held a soldering iron, and went at it.
Thankfully the Goodmans engineers must have had future hifi restorers with big, clumpsy Swedish hands in mind when laying this board out. Not that hard to access and not to crowded. Phew!
Got the VT41 replacement in place, checked and behold: there was minus voltage on the rail again!
So held my breath and mumbled a quiet prayer through gritted teeth to new and ancient higher powers and pressed power...
Big thump in the speakers and then... MUSIC!
Man it was a long time since Bruce Springsteen (playing on my phone through aux input) sounded this good!
Tested tuner: check! (but the tuning did not like the chilled out workshop and was stuck. Simulating normal indor temp with a hairdryer made it move again)
Phono input: check! An old Link Wray record on the Lenco sounded really nice. The riaa in this thing means business.
So good old Goodmans is back from the dead! Now onto a proper cleanup and some new lamps.
Since I was paying more shipment than value of the transistors I also added on the order replacement capacitors for the big blue Erie supply reservoir caps (C144, C145).
Should I replace those or leave them in? The seem to be in good shape.
Any other preemptive actions to take to steer clear of future trouble?
I know a full recap probably would be advisable, but I m kind of a "if it ain't broken don't fix it"-guy
But all and all, I'm a happy camper right now.
And to you gentlemen who has adviced me in troubleshooting I owe a big thank you! ...and a pint or two if and when we cross paths!
Here's a video with "proof of life":
https://drive.google.com/folderview?...BmRmgzMFp2_R-B
Old 20th Oct 2020, 9:04 am   #32
tony brady
that looks really nice in white and a good result to get it working!
as you have the supply capacitors you may as well change them anyway observing correct polarity when you fit the new ones. those Erie caps are 45 years old at least and they can often leak from the vent.
other than changing any callins ( black) electrolytics ( if fitted) I would not do a full recap. do not be tempted to change any capacitors in the tuner section anyway ( except electrolytics) otherwise you will have to re-align the RF & IF stages and that requires test gear
really if it's working ok leave it alone and enjoy it as it is
Old 20th Oct 2020, 11:43 am   #33
CrazySwede
CrazySwede's Avatar
Thanks for advice. Ok, think I'll just replace the big Erie's as a starter.
But not entirely sure about the polarity on these guys. Cannot find any clear markings (maybe hidden under the clamps?). But am I guessing right that the red wires are terminated on a positive lead and the black is negative?
Old 20th Oct 2020, 11:57 am   #34
tony brady
one cap is for the positive supply and one for the negative. The red wire should be the positive supply. the black wire should be the negative. the tinned wire going from one cap to the other is the 0V.
there should be a red marking on the end of the cap painted on the rivet for the positive tag. be careful though as the cap on the negative line will have the red terminal connected to the 0V wire with the black wire connected to the -V terminal
Old 20th Oct 2020, 12:06 pm   #35
CrazySwede
CrazySwede's Avatar
Ahh, so that what those red dots on the caps mean .
But as long as I match the red dotted tags on the old capacitors to positive marked tags on the new ones I am goood?
Old 20th Oct 2020, 12:08 pm   #36
chriswood1900
In your picture the RH cap is red + pos green - neg, on the LH side Green is + and the black -, if I remember correctly Erie caps used a coloured dot on the terminal to denote polarity.
Chris Wood
BVWS Member
chriswood1900 is offline
Old 20th Oct 2020, 12:27 pm   #37
CrazySwede
CrazySwede's Avatar
Thanks, I think I got it now
Old 20th Oct 2020, 3:30 pm   #38
turretslug
turretslug's Avatar
When you come to unsolder/remove the original capacitors, check with a voltmeter to make sure that they are absolutely discharged- depending on the circuit design and the condition of the capacitors, charge can linger for a surprisingly long time after switch off. Even if they only measure a few volts some time after disconnecting power, they can still deliver a hefty current spike if soldering iron or cutters short to something and that can kill semiconductors all over the place.
A painful and embarrassing lesson that sticks in the mind....
turretslug is offline
Old 20th Oct 2020, 3:58 pm   #39
CrazySwede
CrazySwede's Avatar
Thank´s for the heads up about that. Will handle them and the iron with care.
Old 20th Oct 2020, 4:41 pm   #40
Nickthedentist
Nickthedentist's Avatar
Well done for getting this lovely thing going again. I wonder how many ended up in Sweden? Was Goodmans well known there in the 1970s and earlier? Note that the "Goodmans" name that appears on cheap Chinese TVs etc. nowadays is nothing to do with the original company.
I rescued one a few years ago as it was going to be dumped, having been replaced with a little Philips micro system. It worked very well, though the controls always tended to crackle. I gave it away in the end to somebody whose own one had been destroyed in a flood.
I also had a Module 80 receiver with inbuilt GL-75 turntable once, which I was very fond of. The One-Ten was often found with the later GL-85 built in: https://www.picclickimg.com/d/l400/p...GL-85-with.jpg
Or sometimes a Garrard:
https://www.picclickimg.com/d/l400/p...rrard-Zero.jpg
N.
Nickthedentist is offline
