15th Jan 2022, 8:07 pm | #1 |
Pye Black Box.
Hi Folks, for my sins I see quite a few of these amps for repair. The later ones using PCL83's are noted for their feedback instability, but the earlier EL 42 types are normally OK.
There appears to have been occasionally factory problems with the early triode connected EL42 types in that the cap across the tone control was sometimes increased from 0.04uF to 0.14uF. (This appeared to be a final test mod) The later UL connected EL42 amps also had stability problems, which I recently cured by reducing the value of the resistor in series with the bottom end of the vol control from 39K to 18K. In most cases these are ultrasonic oscillations at about 50 to 80KHz, easily visible on a scope and also increasing the output valve cathode voltage from about 17 to 19 volts. I'm sure this increased current then leads (with contributions from leaky caps) to transformer burn out Ed |
16th Jan 2022, 7:04 pm | #2 |
Re: Pye Black Box.
I thought this rang a bell and you'd recently posted on this, so I just found it and added a link to it, as it's an interesting topic:-
https://www.vintage-radio.net/forum/...d.php?t=187281 In the PCL83 version I've replaced the four critical capacitors C6,7,9 & 10 @ 0.04uf (or is it 0.05uf in some models?) with 0.1uf - works well! |
