15th Jan 2022, 2:26 pm | #1 |
Modern speakers suitable for Leak stereo 20
Recommendations gratefully received for any advice on speaker choice for use with Leak Stereo 20.
15th Jan 2022, 2:43 pm | #2 |
Re: Modern speakers suitable for Leak stereo 20
That is a very good question !
I guess any loudspeaker would work, but of course in reality you really want something that offers a reasonably even impedance with frequency response. Not to mention good sensitivity too. Something with at least 90db at 1 watt. In the late 90's, I had a Stereo 20 and used it with Mission 752 speakers. These were a good match at 8 ohms with 90db, but of course probably not classed as modern now. They sounded excellent with plenty of volume I remember. I guess a good starting point would be to decide upon a budget and then look at the data of possible choices to see if they come close to the ideal. It is of course worth keeping an open mind to the possibility of buying a used pair of suitable speakers too.
Andrew |
15th Jan 2022, 2:58 pm | #3 |
15th Jan 2022, 3:03 pm | #4 |
Ah !!
Another important requirement has just been added..... WAF. (Wife Approval Factor). You now have a difficult (but not impossible) job on your hands sir !
Andrew |
15th Jan 2022, 3:04 pm | #5 |
A high sensisitivty of around 91dB is almost essential for the Leak Stereo 20. Tannoy floorstanding reflex speakers of 1980-95 would be ideal.
Edward. |
15th Jan 2022, 5:02 pm | #6 |
As said, just remember that it's 20W total from both channels, and quite significantly lower power than the sort of things most modern speakers are designed around. So you need something reasonably efficient. That rules out the crazy inefficient ones.
15th Jan 2022, 5:10 pm | #7 |
Some nice horn loaded jobs? Plenty of noise available then
15th Jan 2022, 5:57 pm | #8 |
I'm going to chuck a curved ball in.
based entirely on my own empirical experience. I don't swap in a conventional pair of speakers when I want to listen to my Stereo20, I simply plug it into the Quad ESL989 in my medium sized listening room and the amp doesn't bat an eyelid. Many were used with the original Quad ESL57 with no issues. Valve amps of a sound design can cope with these difficult loads. My other speakers are a smallish set of standmount Kudos cardea1 which I think are around 86dB/W, and they seem plenty loud enough to me. I've used , in the past a pair of Wharfedale Diamond9 budget jobs and they were fine, and previously My old Monitor Audio Monitor3 gold floorstanders and a pair of Usher S520 small stansdmounts. All worked just fine and enough volume to annoy the distaff side. I think any decent speaker with a reasonably steady impedance characteristic will be just fine. There's a lot of hot air wafted around this sort of thing, fanned by certain magazine contributors. If you're going to be buying new, or used from a dealer , then take the amp along and ask for a demonstration. If the dealer fobs you off or otherwise strings a line then walk away and take your business with you. Buying online and used comes with its own caveats. A good dealer should also let you take a demonstration pair home to try, it would be reasonable to expect to pay a refundable deposit especially if the shop doesnt know you. Best Regards. Andy |
15th Jan 2022, 6:16 pm | #9 | |
I guess the choice ultimately comes down to what you like the sound of, plus the WAF, so audio and domestic harmony may be achieved. Any HIFI dealer worth his salt should only be too happy to cater for a demonstration with the amplifier and a sensible selection of speakers.
Andrew |
15th Jan 2022, 6:19 pm | #10 |
Do you have a rough budget in mind....New or vintage...
15th Jan 2022, 7:03 pm | #11 | ||
The general advice for a hifi system is to start with the speakers - find a pair which work well in your room and whose sound you like. Then find an amp which will drive them as loud as you like. Cheers, GJ
http://www.ampregen.com |
15th Jan 2022, 8:48 pm | #12 | |
Rick, the annoying object roaming the forum. |
16th Jan 2022, 12:05 am | #13 |
The overriding consideration here appears to be the WAF - any clues as to what size or type of finish is likely to be acceptable?
16th Jan 2022, 12:51 am | #14 |
Lol...To achieve 100% WAF requires the speakers to be as small as practicable with no visible wires. The cloth should preferably be available in a choice of colours. Cabinets should be in Beech or Maple. So...no much to ask!!
16th Jan 2022, 12:57 am | #15 |
Offer to drape some cloth over the SIDES, NOT the front of the boxes. Paisley was very "in" during the Leak period . Florals were nice too !!. Nice potplants work too. Just make sure they dont leak ( pun intended ).
Play the game, She will come around. Joe |
16th Jan 2022, 10:21 am | #16 |
Quad ELS's out then
I was going to suggest if looking vintage Ditton 33's or Kef Coda's of if very deep pockets LS3/5a's - depends on how much bass you want. I have an elderly pair of Spendor BC1's which i have happily driven with a smaller amp - Rogers Ravensbrook previously. |
16th Jan 2022, 10:33 am | #17 |
If it were me, and I could afford it, I would love to try the Rogers LS3/5A.
Now personally, I don't like high volume neither do I crave oodles of bass, so it would be very interesting to hear such a set up. I think it could be rather good... But you would never be able to rattle the window's with 10 watts and 82db sensitivity ! In this instance, quality over quantity would be the order of the day. Oh, and they look nice and are not too big. The good lady may approve, until she see's the price lol.
Andrew |
16th Jan 2022, 10:34 am | #18 | |
Pick something decidedly more than you think you'd get away with, with the intent of compromising back to something still decent that wouldn't have been OK if suggested directly David
