13th Jan 2022, 12:03 pm | #1 |
Philco 108
I received the above radio. But the cables are off the speaker transformer. They are red blue yellow I have taken pictures not sure what order they should be in could any one help please.
13th Jan 2022, 12:50 pm | #2 |
Re: Philco 108
This is harder to explain than do!
You need to check the resistance between the pins of the transformer. The two outer pins will probably read about 400Ω The centre pin to the pin furthest away will probably also read a similar figure. The two closest pins will read a low resistance. If all the above is the case then the yellow goes to the centre. Red to the close tag and blue to the far tag. If it doesn't read as above you need to report your findings Cheers Mike T
14th Jan 2022, 12:22 am | #3 |
Re: Philco 108
Thank you perfect works well
