3rd Dec 2021, 2:21 pm | #1 |
Why did Leeds get the 0532 dialling code ?
The major cities were issued with 01, 021 and so on. I assume the GPO simply ran out of numbers in this sequence, meaning Leeds had to make do with something more random. Or was there a more scientific reason ?
Thankyou. |
3rd Dec 2021, 2:32 pm | #2 |
Re: Why did Leeds get the 0532 dialling code ?
Googled it. It seems Liverpool got the L = 5. M=6 for Manchester. 7 8 and 9 were not allocated.
3rd Dec 2021, 2:40 pm | #3 |
Most cities and towns used a different model for numbering and leeds conforms to this.
LE = 53. This must have been the second one of these (LEdbury was the first) so Ledbury 0531 Leeds 0532. One that disappeared, Nuneaton. NU = 0682 (0681 is Mull) |
3rd Dec 2021, 2:51 pm | #4 |
'0' was just the STD prefix. The major city codes were essentially shortcodes because these exchanges received a lot of incoming calls, so London got 1, Birmingham 21, Edinburgh 31, Glasgow 41, Liverpool 51 and Manchester 61. Most places got 3 digit codes loosely based on the first 2 letters of the exchange name, so SToke-on-Trent got 782, STafford 785, LEeds 532 etc.
3rd Dec 2021, 3:00 pm | #5 |
Thankyou all. Wasn't Tyneside, Newcastle and Sunderland etc 091 ?
3rd Dec 2021, 3:03 pm | #6 |
Yes, I always forget that one.
3rd Dec 2021, 3:16 pm | #7 |
091 was a later addition, around the time London was split into 071 (for Shirley in Temple!) & 081 (for Eric in Clapton!).
3rd Dec 2021, 7:36 pm | #8 | |
For many years, Orange listed the name of the exchange called on the bill. The exchange I often called was Dapple Heath, which is a tiny hamlet of just a few houses, though the actual exchange was Weston. I suspect this oddity was also to do with how the numbering system had originally been split. |
3rd Dec 2021, 8:44 pm | #9 |
I just naively assumed that 0532 was a random number, not realising that it was related to an exchange name. I was working on the BT Paging service in 1995 when the code was changed completely to 0113. Many customers, not unreasonably, complained that 01532 wasn't working!
3rd Dec 2021, 10:00 pm | #10 |
Lots of places got codes that didn't correspond to the exchange name for whatever reason. Oxford got 865 for example.
3rd Dec 2021, 10:29 pm | #11 |
Of course Oxford was originally 0092 (0OX2), but was later changed to 0865 (in early 1970s?) when all the 00 codes were eliminated prior to 00 becoming the international access code (which was previously 010).
3rd Dec 2021, 11:12 pm | #12 | |
It does lead me to wonder about the allocation of country codes. As above to call my friend in France I dialled 01033.. To call home when there, 1944.... Germany code 49, Poland 48, UK 44. Can't see it being an alphabetic thing, or even any kind of geographic logic so next discussion? |
4th Dec 2021, 12:00 am | #13 |
19 was basically the French STD code, so to call anywhere outside your immediate area you dialled 19 and waited for a dialtone, then dialed the rest of the number. I've no idea if it still works like that. Funny lot the French
4th Dec 2021, 3:20 am | #14 |
19 was the French international egress code, before it became 00
-- Graham. G3ZVT |
4th Dec 2021, 3:34 am | #15 |
Geograhpy was followed slightly, sometimes. From top to bottom of the coastline:
31 The Netherlands 32 Belgium 33 France 34 Spain 351 Portugal (other 35x distributed randomly over Europe) Other country codes also seem to be somewhat grouped together. 3-digit country codes were apparently used for smaller countries, or in case of 420-421 and 381-389 for countries that used to have a 2-digit code but were split up. |
4th Dec 2021, 11:30 am | #16 |
You may well be right and memory is playing tricks, but when I was staying in Paris in the early 80s I'm sure it was necessary to dial 2 digits (which I remember as 19) and wait for a dialtone before dialling ether a non-Parisian French or international number. It's a long time ago though.
4th Dec 2021, 12:21 pm | #17 |
To dial Leeds from northern France ( anywhere outside Paris) in the 1980s was '19 44 532 xxxxxx'. I seem to remember it was the same from Greece in the 1990s.
5th Dec 2021, 12:54 am | #18 |
International dialling codes consist of an international access code + country code + local number with area code if applicable. Callers from abroad do not dial the initial 0 of UK and most other countries' area codes, or the initial 9 of Spanish area codes.
In the UK, the international access code used to be 010. From France it used to be 19. From the USA and Canada it's 011. Other countries had other international access codes. Europe eventually introduced a standard international access code from all EU countries which is 00. The country codes are internationally standardised. 1 = North America and Caribbean 2 = Africa 3,4 = Europe 5 = South America 6 = Australasia 7 = Russia & former Soviet Union 8,9 = Asia In the case of Europe, country code 35x is used by a number of smaller European countries, eg. 351 = Portugal 352 = Ireland 353 = Luxembourg and so on. In the case of North America and the Caribbean, it's the area code that determines which country the call goes to. There's no obvious way to tell whether a number is in the US, Canada or the Caribbean, or how much you'll be charged to call it. I happen to know Area code 809 is in the Caribbean. In the past, North American and Caribbean area codes always had a 0 or 1 as their second digit but this is no longer the case. Also, local numbers were not allocated in the range 555-xxxx except 555-1212 which was directory assistance / enquiries. Hence you always see phone numbers beginning 555 in American movies, because those numbers are fictional and do not actually exist. |
5th Dec 2021, 2:13 am | #19 |
To understand how UK area codes were allocated, you need to go back to when major cities first had automatic dialling. Dials had letters and numbers. Local numbers in big cities had a 3-letter exchange name and 4-digit number e.g. in London, SKY 4321 was the number for Heathrow Airport and ABBey 1234 was the number for London Transport.
It was thought that a name + 4-digit number would be easier to remember than a full 7-figure number. Most people can remember 4-digit numbers without having to write them down, hence bank ATM cash cards have 4-digit PIN codes. UK dials had the following letter+digit combination: 1 - no letters 2 - ABC 3 - DEF 4 - GHI 5 - JKL 6 - MN 7 - PRS 8 - TUV 9 - WXY 0 - OQZ (In the US, the letter O is the digit 6. In the UK the letter O was the digit zero to avoid confusion between 0 and O.) When subscriber trunk dialling was introduced, London was given the code 01, perhaps not surprisingly as it's Britain's capital city. The other major cities were given 0x1 codes where the x is the first letter of the city name converted to a digit as in the list above. e.g. 021 - Birmingham (B=2) 031 - Edinburgh (E=3) 041 - Glasgow (G=4) 051 - Liverpool (L=5) 061 - Manchester (M=6) 071 and 081 were initially not allocated, but later became inner and outer London area codes between 1990 and 1997, eventually replaced by 020. 091 - Wearside and Tyneside (W=9) Although I think the last code came later, it fits in with the alphanumeric sequence. Edinburgh is a relatively small city. There was no need for 7-digit local numbers, but because Glasgow had them, how could the capital of Scotland not have them? In order not to be outdone by Glasgow, Edinburgh phone numbers were made longer by repeating the first digit which was then absorbed by the exchange. Other towns and cities which didn't have 7-digit numbers were given area codes beginning 0 + first two letters of place name + another digit, e,g. 0BR2 = Bristol (0272) 0BR3 = Brighton (0273) 0BR4 - Bradford (0274) and so on. For place names with two words e.g. High Wycombe, Bishops Stortford the first letter of each word was often used, so High Wycombe was 0HW4 or 0494 in digits. Can you see the pattern now? I'm still not sure how the last digit was chosen, though. |
5th Dec 2021, 2:41 am | #20 |
A great explanation. Thank you
Steve.
