Old 27th Nov 2021, 8:26 pm   #1
Des Miles
Default Morse inker.
Definitely not telephony, maybe Telecomms. Mods please delete if necessary.
Unearthed after being squirreled away for +/- 40 years ago (in my garage rafters) that I had actually completely forgotten about! The instrument had actually been used in the Walvis Bay maritime radio station (ZSV). The station was first operated by the Germans (German South West Africa) and then by RSA - Namibia after it was liberated end of WW2.
The instrument as manufactured by "Siemens Brothers and Company Limited England 1862". I guess it must be a good 100+ y.o. Made completely of brass you can see, from age, that the patina of the brass is red in some places.
The clockwork mechanism still works and the paper tape still feeds. The large solenoids' that would have keyed the system are still OK ( test at 510 ohm.)
What to do with it? A good project to clean up and polish all that brass bits and pieces, or just leave it as is. Any one wager what it could be worth or of any interest?
ID:	246765   Click image for larger version
ID:	246766   Click image for larger version
ID:	246767   Click image for larger version
Des Miles is offline
Old 27th Nov 2021, 8:40 pm   #2
Dave Moll
Dave Moll's Avatar
Default Re: Morse inker.
Telegraphy is definitely part of telecommunications - and a very fine piece it looks. My personal preference would be to retain the patina rather than polish it up, but that's up to you as its owner. I would certainly advise leaving as is if you're intending to sell it.
Again, if it were mine I would want to have it working if at all possible. Is it possible to wire it such that signals from the key are looped back to the inker by way of a demonstration.
Dave Moll is offline
Old 28th Nov 2021, 11:52 am   #3
peter_scott
peter_scott's Avatar
I would mirror everything that Dave suggests.
Peter
peter_scott is offline
Old 28th Nov 2021, 2:26 pm   #4
Another "if it was mine", a complete restoration to like new and working, I may even include a little box that sends morse and powers it for demonstrations. That may reduce the "value" but it would be a lovely thing to behold. Musea (plural for museum I guess) are full of old tatty stuff, to see a hundred year old bit of kit as it was "back in the day" would be a revelation.
Don't get me wrong, I love musea and have yet to find a Roman skeleton uncleaned.
Old 28th Nov 2021, 2:28 pm   #5
Radio Wrangler
Radio Wrangler's Avatar
I think it's best staying with you in the part of the world where its history lies.
Otherwise, it's hard to pin a price on it. At a specialist auction the prices could go high if you happen to get two people who want it. But that would separate it from its history.
Do you happen to have any maritime radio stations set up as museums in the area?
Radio Wrangler is offline
Old 28th Nov 2021, 3:01 pm   #6
Des Miles
David[/QUOTE]
Alas no, any history related to the colonial era is viewed with disdain.
Old 28th Nov 2021, 3:30 pm   #7
G6Tanuki
G6Tanuki's Avatar
It's rather lovely! Lasttime I saw something like that it was described as an "Undulator".
I'd get it working, and - as mentioned above - make up something that can send Morse to it as a demonstration [I'd suggest one of the cheap electronic 'voice recorder' things available for a few pounds, used to record tones, then on playback a diode to convert the tones to DC which then drives a switching transistor to drive the coil].
G6Tanuki is offline
Old 28th Nov 2021, 4:52 pm   #8
Radio Wrangler
Inkers draw dots and dashers. Undulators keep a pen in contact and deflect it to the side with the signal producing undulations of signal dependent amplitude. They're reckoned to be better suited to subtle interpretation than all-or-nothing inkers.
Old 29th Nov 2021, 9:29 am   #9
greenstar
greenstar's Avatar
As with a lot of things I find telegraphy fascinating. Your sounder is delightful, I would just try to get it working with a light clean. I believe inkers were often used with sounders, as the coils on the inker didn't always make a loud enough sound, perhaps in an office with several lines. I made a sounder from an article in one of the boy mechanic type books, and it makes a fantastic clunking sound. They were used with a hood to direct the sound.
You can of course find other telegraph items, but they tend to be pricey.
Tony
ID:	246891   Click image for larger version
greenstar is offline
Old 29th Nov 2021, 9:56 am   #10
John M0GLN
John M0GLN's Avatar
Lovely bit of equipment, the red patina could be a sign of dezincification, perhaps some dampness over the years has caused zinc to leach out of the brass and leave copper showing red, of no importance in this case.
John
John M0GLN is online now
Old 30th Nov 2021, 12:52 pm   #11
M0AFJ, Tim
M0AFJ, Tim's Avatar
We have a working Inker at the Marconi Wireless Museum at Bass Point on the Lizard, worth a quick visit if you’re doing the Cornwall coastal path
M0AFJ, Tim is offline
