17th Nov 2021, 7:53 pm | #1 |
Radio ID required
Hi. Can anyone ID this radio for me. Maybe someone is familiar with the look of it, the dial might give it away. Thank you. Rich
18th Nov 2021, 5:27 pm | #2 |
Re: Radio ID required
It appears to have Stagshaw on the dial so it may be prewar.
A rear view of the chassis would be helpful. |
18th Nov 2021, 6:50 pm | #3 |
I agree, probably late 30s by the tuning scale, though it may be immediately postwar. What are the valves?
18th Nov 2021, 8:35 pm | #4 |
I attach a picture of the top of the chassis and a date found on the speaker. Cannot make it out though. And speaker is not absolutely known to be the original. Valve line-up (markings on valves) : 6K8G (Brimar), 6K7G (Brimar), 6Q7G (Brimar), 6F6G "Amerty Mullard", 5Z4G / CV1863 (Gov. mark) and the magic eye 6U5 (Tungstram) Not sure if the valve line up says something. EDIT: I include it's original setting. Is this a "console" set?
18th Nov 2021, 8:50 pm | #5 |
Is the smoothing can dated?
-- Graham. G3ZVT |
18th Nov 2021, 9:14 pm | #6 |
The smoothing can has been replaced with a radio-spares one. I attach a shot of the underneath. In the LW section of the dial I see "Aircraft".
18th Nov 2021, 10:52 pm | #7 |
Well it is a console set.
Otherwise it's hiding its identity quite well! The 6F6G isn't a common valve in UK models, the 6V6G was far more popular and used less heater current. The 6k8g 6k7g 6q7g 6v6g 5z4g lineup was used quite widely, but none listed in Radiomuseum match your chassis. Maybe it's an obscure "Department Store" set?
19th Nov 2021, 9:18 am | #8 |
Lewises was a department store located in Leeds in the county where I live. Wonder if Lewises had it made.
15th Jan 2022, 10:10 am | #9 |
Barker 88 maybe?
15th Jan 2022, 10:39 am | #10 |
Looks likely:-
https://www.radiomuseum.org/r/barker_88.html It's a pity we don't have picture of the front.
15th Jan 2022, 12:58 pm | #11 |
Trawler band is a fairly unusual feature, otherwise it looks typical of 1938-45 (not much development of domestic sets during WWII, and more than a few post-war models were released with pre-war station names) department store or rental sets.
Paul |
15th Jan 2022, 4:05 pm | #12 |
It looks rather like an Armstrong chassis, albeit a basic model, from about 1938.
Neil
15th Jan 2022, 4:38 pm | #13 |
The capacitors in the dull metal cans look very much to me to be Sprague ones of US manufacture - many of these were on the surplus market in the immediate post WWII period and were used extensively in radios made up until the early 1950 s.
It doesn't have enough valves to be a Barker 88, my guess is that it is something made up by one of the many post WWII small businesses that sprung up back then.
15th Jan 2022, 4:58 pm | #14 |
I would also go Armstrong, look at the position of the rear valve WRT the IFT's in the ones in the links below and compare to the OP's photo, definitely a family relationship there:
https://worldradiohistory.com/hd2/ID...22armstrong%22 https://worldradiohistory.com/hd2/ID...22armstrong%22 This one might be a reverse image?: https://worldradiohistory.com/hd2/ID...22armstrong%22 Lawrence. Last edited by ms660; 15th Jan 2022 at 5:12 pm. Reason: link added |
