26th Sep 2022, 2:38 pm | #1 |
SAA3021X Siglent Spectrum analyser
Hi peeps.. Apart from Terry VK5TM I wonder if any members have use or knowledge of this "fine" piece of equipment.
To date I have had no reason to use the Store feature. However I needed to store some filter wave shapes, which it does. However recovering them is impossible... the User Manual is less than helpful. Have any of you members come across this ?? and if so...how do I see my stored wave shapes please
Should get out more. Regards Wendy G8BZY |
29th Sep 2022, 11:42 pm | #2 |
Re: SAA3021X Siglent Spectrum analyser
I have recently purchased the SAA3021x Plus version which has touch screen and save option for USB memory stick or internal storage. I can view the filter responses on PC easily by saving the files in different format. I have not come across the Store option in the plus version manual.
29th Sep 2022, 11:57 pm | #3 |
Attached is the saved screenshot of the noise floor about -160dbm at 50MHz, at RBW=1Hz which is very good and close to the datasheet.
30th Sep 2022, 10:27 am | #4 |
Hi Regen.. I can save them.... just not display them...... Siglent has not yet come back to me .
17th Oct 2022, 8:14 pm | #5 |
Hi Wendy,
I have a SVA1015X Save as a Trace file (TRC) then you can recover it. I was looking for your VHF Oscillator Design thread and saw this Is your equipment "Hacked" ? If yes, please in VNA mode, can the IF bandwidth go below 10 kHz? Thanks |
20th Oct 2022, 12:12 pm | #6 |
Re the above. As I dont know your name. I will try what you suggest.. Thanks No it is NOT hacked . It was returned to Siglent about 20 months ago, for a software problem, which was sorted. I will give it a try this UK PM
