Old 17th Sep 2022, 1:58 pm   #1
murphyv310
murphyv310's Avatar
Default Advance EHT & 6.3v PSU front panel
Hi
I've recently acquired the above in rather poor condition, internally its pretty well perfect, the variable EHT control was seized but after dismantling the nylon bush needed to be carefully reamed, after lubrication all is well, also a 1M resistor was open circuit to the EHT meter. My problem is the front panel, it's quite badly rusted, I don't even know the model number, information would be useful and even a scan of the front panel.
I couldn't find any info online. Photo is after respraying the case.
Cheers,
Trevor.
MM0KJJ. RSGB, GQRP, WACRAL, K&LARC. Member
murphyv310 is offline
Old 17th Sep 2022, 2:26 pm   #2
Alistair D
Alistair D's Avatar
Default Re: Advance EHT & 6.3v PSU front panel
These people are ex Advance and Farnell PSU design engineers.
If nothing else they might be able to give you a model number.
Al
Edit: It would be helpful if I had posted the link! Doh.
https://advanceproductservices.co.uk...-repair-list/#
Alistair D is offline
Old 17th Sep 2022, 3:33 pm   #3
radioman
radioman's Avatar
Hi Trevor,
I thought it was a PP-12 (check back panel...)
Andy
G-QRP #12697
radioman is offline
Old 17th Sep 2022, 3:55 pm   #4
murphyv310
murphyv310's Avatar
Indeed it is a PP12, thanks Andy.
Never gave the back panel a second look.... Oh dear.
Anyway I still need a scan or a front panel.
Thanks Al for the info and link.
Cheers,
Trevor.
