4th Sep 2022, 11:01 am | #1 |
Ampex 90081-12 motor
I've been given an Ampex motor marked 107V 58/62 c/s 4.5A Part 90081-12 Type REEL. Cap 25uF. It was almost certainly from some kind of tape recorder. Does anyone know what it might have been from? Provenance is likely to have been ex-BBC. Now the intention was to reuse as an AC motor since it has lovely smooth bearings that just keep spinning, but before doing that I wanted to check that it wasn't of greater utility to someone trying to repair an old Ampex machine as I hate repurposing parts that could have been used for a restoration. Alan |
4th Sep 2022, 11:48 am | #2 |
Re: Ampex 90081-12 motor
The fact that it is a nominal 60Hz frequency motor (i.e. 58/62 c/s) could indicate that it originally was for the USA market or Japan.
David |
4th Sep 2022, 12:37 pm | #3 |
Checking my Ampex 1163 (export version of the 1160) I see it has a dual frequency 50/60 Hz, 117V (117V derived from transformer) motor. This motor is only 0.5A so the 4.5A motor must be quite large.
To convert the 1163 from its default 50Hz to 60Hz requires a conversion kit of 3 x pulleys and a motor capacitor. David |
4th Sep 2022, 12:42 pm | #4 |
Perhaps a motor from an Ampex open reel video recorder ?
4th Sep 2022, 1:33 pm | #5 |
It is indeed quite large and it wouldn't look out of place on a bench top drill press standing at just under 6inch diameter.
I has forgotten the Ampex VTRs; I've never seen any pictures of the innards only the consoles and reels. |
