5th Sep 2022, 5:35 pm | #21 |
Re: Uher SG 561 Royal
Hi David,
Yep that's the same head block as mine, the dual quarter track. Correct also with the common wires being the ywllow and white. Right channel measures same as yours, about 3.45kOhm. Left channel climbed to over 200MOhm... I think we have a winner! |
5th Sep 2022, 5:48 pm | #22 |
Most likely is the head itself but of course could be a bad connection to/from the resistor.
David |
5th Sep 2022, 8:23 pm | #23 |
Does yours have an intact foam gasket/seal at the bottom panel air intake that interfaces to the bottom of the motor.
On all my similar Uhers the foam gasket is always long gone, so wonder what it looks like. David |
5th Sep 2022, 11:59 pm | #24 |
Hi David,
It has definitey started to perish but it is still there, if I'm not mistaken it's actually cut to the shape of a square. If I get time tomorrow I'll open it up and snap a picture Cheers |
6th Sep 2022, 10:19 am | #25 |
Hi David,
Picture attached so you can see what has survived in mine. Also forgot to mention, in that pic you can see red plastic that appears melted and stuck to the case near the vent on the left. There's quite a bit of it littered around inside. At first I thought it was wire but it's set solid. |
6th Sep 2022, 1:01 pm | #26 |
Thank you for the photo, I have seen the red stuff before in some of the Uher Royals, it has always mystified me what it is.
David |
8th Sep 2022, 6:02 pm | #27 | |
David |
8th Sep 2022, 8:40 pm | #28 | |
David |
10th Sep 2022, 11:15 am | #29 |
Hi David, I was referring to a Yamaha keyboard. It has stereo line level phono out so I was using it as an audio source to test the line inputs.
Probably just minor differences between each one, likely the speakers as you say |
11th Sep 2022, 10:17 am | #30 |
I am probably being thick but still cannot really visualize this.
Is it a PC keyboard, where do the line signals come from, does the keyboard have line level phono inputs that connect to your Hi-Fi amp or can the keyboard generate audio signals ? David |
11th Sep 2022, 10:27 am | #31 |
Electronic piano...
Lawrence. |
11th Sep 2022, 10:35 am | #32 |
Ah that now makes sense, I have some music keyboards that I think have phono line outputs, will have to try this myself.
David |
11th Sep 2022, 11:34 am | #33 |
Sorry for the confusion David, I see what you mean now; yes a musical keyboard, one of the old 80s Yamaha Portasounds.
Not many had dedicated phono line outs but this one does, and given that the mic input on the 561 is another DIN that is expecting a stereo mic, it was the easiest solution for checking the input monitoring and recording. |
13th Sep 2022, 3:54 pm | #34 |
