Old 11th Jan 2020, 11:05 pm   #1
WattyMan
Question Smiths sectronic Mk1
I’m new to this forum so forgive me if this is a common / impossible ask.
I have come across an old’ish mantle clock that was awarded to my Grandfather for his many years of service to his local Methodist Chapel. It has what I think I have identified as a Smiths sectronic Mk1 movement that doesn’t work.
Is a repair possible? Is there someone who would carry out a repair?
WattyMan is offline
Old 12th Jan 2020, 12:31 pm   #2
Mike Phelan
Mike Phelan's Avatar
Default Re: Smiths sectronic Mk1
Hi Wattyman,
It's certainly worth repairing. I'm assuming it doesn't work?
Any chance of a picture, front and back?
Mike.
Mike Phelan is offline
Old 13th Jan 2020, 9:35 pm   #3
Robsradio
The Sectronic mk1 has a moving coil movement, the faults with these are either the coils have become scuffed by the permanent magnet, this usually happens if the clock gets a heavy knock whilst running. I have also seen leaky or dud germanium transistors and a leaky capacitor. It is not usually a mechanical fault.
Rob
Robsradio is offline
Old 14th Jan 2020, 9:50 am   #4
Mike Phelan
This http://www.mridout.force9.co.uk/ecw/sectronic1.htm might be of use to you.
Mike.
Old 17th Jan 2020, 12:14 am   #5
WattyMan
Hi, I’ve attached a few images of the clock which I did have dismantled the other day and could do so again if needed.
WattyMan is offline
Old 20th Jan 2020, 9:58 pm   #6
WattyMan
Sorry, didn’t attach the right ones.
ID:	197507   Click image for larger version
WattyMan is offline
Old 24th Jan 2020, 7:16 pm   #7
Graham G3ZVT
Graham G3ZVT's Avatar
Are the battery contacts clean and bright?
Graham.
G3ZVT
Graham G3ZVT is offline
Old 26th Jan 2020, 7:16 pm   #8
WattyMan
Yes, all clean and ok, I don’t know when it last worked as it was my Grandfathers, he died over 30 years ago!
WattyMan is offline
Old 26th Jan 2020, 9:15 pm   #9
TowerRadio
These clocks need a flick of the wrist when the hand winder knob(white) is pushed in to kick-start the balance,if it going to run this should set it in motion.If you have a voltmeter you can check for 1.5v across the metal contacts with the battery in situ.Les
TowerRadio is offline
Old 26th Jan 2020, 11:26 pm   #10
TowerRadio
Sorry,I got a bit carried away about a flick of the wrist. The moulded instructions on my model say "press to set hands,release to start" It is the releasing bit and some internal cam action that sets the action going so if the white button is spring loaded and moves freely it should start OK (I thought my clock was a non-runner until I read the instructions) Les.
