Old 4th Jul 2005, 10:45 pm   #1
garfy
garfy's Avatar
Smile Aquadag Paint
Hello all,
Does anyone know where i can obtain any Aquadag Paint.
I used to get it from RS in the form of a aerosel but they have discontinued it now.
I only need a small amount to paint a Mazda CRM93 crt to put in a Bush TV22.
Many thanks,
Keith.
garfy is offline
Old 4th Jul 2005, 11:29 pm   #2
mickjjo
mickjjo's Avatar
Default Re: Aquadag Paint
Rapid electronics do an aerosol of graphite coating which should do the job:-
http://www.rapidelectronics.co.uk/rk...0090&XPAGENO=1
Use of this stuff is discussed on this interesting site:-
http://freespace.virgin.net/andy.valve/techa.htm
Regards, Mick.
mickjjo is offline
Old 5th Jul 2005, 12:04 pm   #3
peter_scott
peter_scott's Avatar
Not Aquadag, I know, but I came across it and thought it might be useful someday. http://cgi.ebay.co.uk/ws/eBayISAPI.d...sPageName=WDVW
peter_scott is offline
Old 6th Jul 2005, 9:15 pm   #4
Heatercathodeshort
Heatercathodeshort's Avatar
Hi Keith,
The CRM93 will work very well in the BUSH TV22 without having to 'dag' the bowl of the tube. As you know the coating together with the internal final anode form an EHT smooting capacitor of around .001uf. There is sufficient capacity when the tube is mounted close to the chassis between the bulb and chassis to smooth the eht to a satisfactory degree. Even at full beam current only a tiny amount of line pulling can be observed and even then you would never see it unless pointed out. I am a little concerned about painting an old 50 year old tube with any form of drying paint. The glass is very thin on all MAZDA tubes and any undue strain should be avoided. I stuck the rearview mirror back on the windscreen of my TRANSIT with 'superglue' but was told later that when the warm weather came the screen would crack....You guessed it..All around the mirror mounting and a vertical crack.! Glass becomes brittle when old. It may become a serious problem as these vintage tubes age. JOHN
Heatercathodeshort is offline
Old 12th Jul 2005, 7:27 am   #5
mikelect
mikelect's Avatar
Hi guys after a quick Google found this hope it helps
Mike
http://www.technologysupplies.co.uk/...nt_342144.html
mikelect is offline
