Old 8th Nov 2020, 7:40 pm   #21
Malcolm G6ANZ
Malcolm G6ANZ's Avatar
Default Re: Does anyone remember the 'electronic mouse' circa 1978?
From my memory XEE used the FCHxx series of logic IC's not the 7400 series. These were difficult to obtain and eventually cost my father a lot.
Malcolm G6ANZ is offline
Old 5th Apr 2021, 11:01 pm   #22
unitelex
Originally Posted by Al (astral highway) View Post
Originally Posted by Red to black View Post
Anyway as far as I recall the design I saw used two ORP12 photoresistors or similar located in the mouse's ears, and as you say the whiskers triggered the "backout" option via switches, the design I also recall also used Germanium driver transistors for the motors.
That's the one! Yes, it definitely used photoresistors in the ears and also germanium driver transistors!
This one that you've identified was a lot simpler than some of those being spotted on this thread with logic on board.
I definitely saw it when in around '77-78 or so; as you say it may have been reprinted or something.
It's great to find out more about it all these years later!
Apologies for responding late to this thread, only just noticed it...
I am pretty sure the reference book you refer to is "Physics Projects" by A D Bulman 1972.
Page 22 has "An electronic mouse" designed by sixth former Roger Forshaw an early version of which was exhibited at Cambridge Science Fair in 1965
It describes exactly as you have above. There are two versions of the circuit, MkIII and MK IV, the MKIII uses current control of the motors and the MK IV uses voltage control in bridge driver configuration, the latter being able to reverse individual motors. It has the wire whiskers and the photocells in the ears as described. All germanium transistors OC series GET series PXA, V32/20
I have the book and I could scan the article if anyone is interested.
Chris
unitelex is offline
Old 6th Apr 2021, 12:21 am   #23
Red to black
Red to black's Avatar
That would be great thanks, I am sure Al would also be interested.
I wonder if that same book also had the twin solenoid electric reciprocating motor design in it too ? I did manage to build a version of the latter with the help of some Meccano and tried using reed switches and magnets for timing, I ended up using optical switching in the end.
Red to black is offline
Old 6th Apr 2021, 3:21 am   #24
unitelex
Just checked and yes the book I mentioned does have "A twin-solenoid induction motor" Article 5 page 19
I will scan when I get a minute
Best Regards
Chris
unitelex is offline
Old 7th Apr 2021, 5:39 pm   #25
unitelex
Scans of the circuit and assembly layout
From "Physics Projects" by AD Bulman 1972
This is a school library book that I forgot to return in 1975
Fortunately for me, due to a clerical inadequacy on the part of the school, the loan date stampings do not have the year included. The last date stamped was 10th October, so perhaps I could wait until mid October 2021 and return it.
Name:	Electronic Mouse circuit MkIII.jpg
ID:	231167   Click image for larger version
Name:	Electronic Mouse circuit MKIV.jpg
ID:	231168   Click image for larger version
Name:	Electronic Mouse assembly MKIV.jpg
unitelex is offline
Old 9th Apr 2021, 9:07 am   #26
Andrew2
Andrew2's Avatar
I remember we built one at school. It was very simple, just a basic 3-wheel bogie with a steerable front wheel. It's normal mode would have it going round in tight circles until it detected a light source, when it would snap into 'straight ahead' mode and head for the light. If it lost sight of the light it would go into spin mode again until it found it. I think a similar design appeared in PE around 1968.
Andy G1HBE.
Andrew2 is offline
Old 9th Apr 2021, 8:04 pm   #27
Philips210
Hi.
I doubt this is the article that Al is looking for but there was an interesting robot project with transistor circuitry in Radio and Electronics Constructor magazine which ran from July to December 1972. All issues can be acessed on World Radio History website:https://worldradiohistory.com/Radio_...r_Magazine.htm
Regards,
Symon
Philips210 is offline
Old 9th Apr 2021, 9:44 pm   #28
Ed_Dinning
Also a robot dog was described in one of the Philips tech library books, it used D*** series B7G valves
Ed
Ed_Dinning is offline
Old 10th Apr 2021, 10:10 pm   #29
Al (astral highway)
Al (astral highway)'s Avatar
Thanks for posting! That's the circuit I remember.
I hope folk enjoying taking a look.
Al
