2nd Jun 2022, 3:04 pm | #1 |
Another PR99 Question . . .
Right, this is getting like Tenko!
I am finally there. The heads are perfect, the motors are perfect and it is now calibrated perfectly according to the manual in CAL mode. On the meters what goes in comes out perfectly on tape. On Quantegy 456 it sounds really great. My questions is this. As I said, in CAL mode, on the signal generator and meters its perfect but, when I connect to a standard integrated amp (a Technic SU3500) being fed by tuner with full signal on Radio 3 the level that is coming out of the 'record out' into the deck is minimal. Minus 18 to 20dB at most. If I take it off CAL and use the record level controls I get it up to where I would expect it bouncing along just under 0dB with the occasional flash of red on the peak lights. I assume this is normal, but why?
Small Scotch, New Aids and Happy Ears |
2nd Jun 2022, 3:10 pm | #2 |
Re: Another PR99 Question . . .
Maybe your are trying to feed the PR99's professional balanced inputs with consumer unbalanced outputs from your amp.
2nd Jun 2022, 4:41 pm | #3 |
Your PR99 line in is set to 775mv, the o/p from the amp is 150mv, 1 fifth.
2nd Jun 2022, 5:20 pm | #4 | |
I presume then, that anomaly can be addressed by the jumpers on the input board (if necessary)?
2nd Jun 2022, 11:41 pm | #5 |
It's not an anomaly 775mv is the professional studio level, it was never meant for domestic use.
Graham |
3rd Jun 2022, 12:31 am | #6 |
775mV RMS into 600 ohms is 1mW and was decided upon as the reference level for telephone signals, and it all expanded form there.
3rd Jun 2022, 1:28 pm | #7 |
Ok, perhaps anomaly is the wrong word so apologies. But, there are three jumper settings on the input board to allow for connecting to domestic equipment (I presume). It doesn’t explain whether the deck should be setup at 775mV then move the jumper or, move the jumper and then set up at 775mV though.
