Old 18th Oct 2020, 10:20 am   #1
ValvoStef
ValvoStef's Avatar
Default DIN connector confusion
Morning all.
See the photo, please. Is the DIN connector shown from the solder side or the connector side? I have a plug but unfortunately there are no numbers on the pins, the socket on the radio is not marked either. I guess I have to use pins 1 and 4 to connect a MP3 player to it?
Failing to prepare is preparing to fail ...
ValvoStef is offline
Old 18th Oct 2020, 10:43 am   #2
Default Re: DIN connector confusion
Looks like solder side of the socket to me.
Old 18th Oct 2020, 10:58 am   #3
ajgriff
ajgriff's Avatar
Hoping that the attached PDF might help.
Alan
ajgriff is offline
Old 18th Oct 2020, 10:59 am   #4
vinrads
Looking at the solder end of the plug clockwise goes 1,4,2,5,3. Mick. oops Alan just beat me to it .
vinrads is offline
Old 18th Oct 2020, 11:06 am   #5
snowman_al
snowman_al's Avatar
You can easily establish which way round the socket is with a multi-meter on ohms.
Looking at the socket from the 'outside' measure between the two pins on the right (reference to the middle ground pin 2). If you measure 0 ohms (a short ) they are pins 3 and 5. If you measure 780k ohms they are pins 1 and 4.
I assume for input you mean either pins 1 to 2 or pins 4 to 2? Just using pins 1 and 4 will not work you need to include pin 2 (ground) in any combination.
snowman_al is offline
Old 18th Oct 2020, 11:54 am   #6
ValvoStef
ValvoStef's Avatar
Alan
Thanks, very helpful
Old 18th Oct 2020, 11:56 am   #7
ValvoStef
ValvoStef's Avatar
of course, thanks, I forgot the ground completely.
Old 18th Oct 2020, 6:39 pm   #8
llama
llama's Avatar
I'd pop the skeleton of the plug into the socket and see which two pins give a buzz when touched.
Graham
llama is offline
Old 19th Oct 2020, 12:06 am   #9
Uncle Bulgaria
Uncle Bulgaria's Avatar
It's always confusing, but I've found with the DIN bits I now buy the numbers are moulded into the plug/socket next to the pins. A helpful reference!
Uncle Bulgaria is offline
Old 19th Oct 2020, 9:59 am   #10
Nickthedentist
Nickthedentist's Avatar
...if you've got your microscope handy to read them
Nickthedentist is offline
Old 19th Oct 2020, 2:15 pm   #11
Uncle Bulgaria
Ah yes. Perhaps posts should have an associated questionnaire which gives the poster's eyesight test results, relevant health issues and weekly alcohol consumption! Joking aside, I find my 'third hand' magnifying glass useful for those times when my eagle eyes don't cut it.
Old 19th Oct 2020, 4:48 pm   #12
ValvoStef
ValvoStef's Avatar
Graham
Good idea, really.
Old 19th Oct 2020, 5:36 pm   #13
DMcMahon
DMcMahon's Avatar
This is obviously correct for the circuit shown in Post # 1 but not necessarily correct for other circuits.
DMcMahon is offline
