8th Dec 2021, 11:55 am | #1 |
What are these coils for?
Had these turn up in a box of bits, what are they for. Unfortunately my Chinese do everything tester reads them as resistors. Thanks
8th Dec 2021, 12:03 pm | #2 |
Re: What are these coild for
GPO resistors,someone will tell you exactly how they were used.Les
8th Dec 2021, 12:37 pm | #3 |
So my cheap Chinese test anything was right!
8th Dec 2021, 1:17 pm | #4 |
Re: What are these coils for?
Wound with some sort of resistance wire perhaps?
...where on earth did that spring/screw go?? |
8th Dec 2021, 5:31 pm | #5 |
... and presumably wound back upon themselves to cancel out any inductance.
8th Dec 2021, 8:17 pm | #6 |
I remember a bunch of those - they were non-inductively-wound and also had a temperature/resistance coefficient that compensated for some other odd thermal-coefficient elsewhere in the network.
They were used in an early solid-state 'line-driver' which featured Germanium CV4001-4007 series transistors in an encapsulation that was instantly identifiable as having been made by Texas Instruments Bedford.
11th Dec 2021, 1:21 pm | #7 |
I did have a load of similar components to these I always assumed that they were resistors.
My friends father whom I got them off did work for the GPO. |
11th Dec 2021, 1:56 pm | #8 |
Also used in similar format and non inductively wound on power system protective relays
Ed |
11th Dec 2021, 3:40 pm | #9 |
Resistor, spool No.9. Used by the million in Strowger selectors and relay sets.
They were simple wire-wound power resistors as far as I remember, but there may have been special non-inductive wound ones. There were lower wattage versions wound on a plastic bobbin. |
13th Dec 2021, 6:23 pm | #10 |
Thanks for all the info
