7th Dec 2021, 3:24 pm | #1 |
47 markings on WW 2 capacitors
I recollect a thread on this subject being discussed some time ago but I have been unable to find it so hopefully somebody can help.
Numerous WW 2 components, particularly RAF, have in addition to their values or stores numbers the number 47 included. The pictures below show two examples, a waxed paper and a pear drop capacitor (far left on the pear drop). Numerous possibilities spring to mind, approval level or specific manufacturer. Hopefully somebody knows the answer. Chris |
7th Dec 2021, 6:07 pm | #2 |
Re: 47 markings on WW 2 capacitors
Some more examples.
Andy |
7th Dec 2021, 10:30 pm | #3 |
Just a guess - maybe a date code?
ā47ā = 1947, āEā = May. (Letter E being 5th in alphabet, so = fifth month).
7th Dec 2021, 10:44 pm | #4 |
I don't believe it is a date code, or we would see other numbers just as often, which we don't see marked in this way.
Andy |
8th Dec 2021, 11:20 am | #5 |
TCC.
Google> vintage wharfdale 47e ? Lawrence. |
8th Dec 2021, 1:18 pm | #6 |
Might be a supplier code?
TCC was a big supplier then, so if seen on different parts that might be a possible answer
...where on earth did that spring/screw go?? |
8th Dec 2021, 3:02 pm | #7 |
Thanks for that Lawrence TCC sounds reasonable although I have never associated them with the "pear drop" shown in the picture above.
That particular capacitor does not fit in with the normal range as it has a length of 18-20mm and diameter of around 16mm. Unfortunately the RAF stores number is partially obliterated 10C/3xx3. Chris |
