2nd Dec 2021, 6:48 pm | #1 |
Valve equivalent
I need a 442BU rectifier valve. The R-Type web site says that a UU5 is a replacement for it. But the 442BU is directly heated and the UU5 is indirectly heated. Is that ok?
2nd Dec 2021, 6:53 pm | #2 |
Re: Valve equivalent
Cathode tube is connected to one side of the heater, so in that respect it will be fine.
2nd Dec 2021, 6:54 pm | #3 |
Please explain, thanks.
2nd Dec 2021, 7:04 pm | #4 |
A circuit that uses the directly heated valve has a separate transformer winding for the heater, so there's no problem with the uu5 that has the cathode connected to one side of the heater being used.
Sorry I accidentally hit post before finishing! |
2nd Dec 2021, 8:45 pm | #5 |
And it'll give the reservoir capacitor an easier time on switch on since the rest of the valves will likely be coming on already as the rectifier starts to conduct. Directly heated rectifiers generally warm up faster than (indirectly heated) valves in the rest of the set resulting in a significant surge voltage on the smoothers.
