Old 15th Nov 2021, 7:51 am   #1
nemo1956
Default Hallicrafters SX122A
I've had this radio for a long time now but not used it.
Now it seems very deaf.
I've re-caped it and replaced many of the resistors as they had gone just out of spec and tested all the valves/tubes
but it's still very deaf.
Even the xtal calibrator is very low signal.
Has anyone worked on this radios that can give me a clue?
many thanks.
nemo1956 is offline
Old 1st Dec 2021, 10:34 pm   #2
nemo1956
Default Re: Hallicrafters SX122A
Hi all. Update on this radio.
I found the problem. The two first If transformers had the internal capacitor problem so I very carefully removed them and took them to bits.
The capacitors had lost of white whiskers all over them and had broken. I cut them out and replaced all four (two in each).
Did a realignment and all is well now.
It's working like new again.
nemo1956 is offline
