11th Nov 2021, 4:49 pm | #1 |
Set identification needed
Hello
does anyone have any idea what radio set this is? I obtained it at the Hornsea rally a few weeks ago, obviously a receiver, with 6 octal valves including rectifier, and designed for rack mounting. It looks like there was some kind of identification plate below the dial at some time. On the rear there is a GPO stamp. Cheers Andy G4OJY |
11th Nov 2021, 5:17 pm | #2 |
Re: Set identification needed
The bezel and knobs look like EMI pre-war types- maybe a professional-market packaging of one of their "all-wave" or "export" sets?
11th Nov 2021, 5:34 pm | #3 |
I've just done some cleaning and found a small label inside. Apparently it's an EMI RR20. Just found a thread from 2018 on this forum.
11th Nov 2021, 5:48 pm | #4 |
Looking at the photographs from the 2018 thread I can see I have the same set as the OP in that thread as one of the electrolytics has been replaced by a smaller component.
11th Nov 2021, 8:41 pm | #5 |
Hi Andy, I did a set looking very much like that for a guy up in Northumberland a few years ago. It had been used as a ship's entertainment set and drove a small PA system.
The tuning knobs certainly look HMV/ EMI Ed |
12th Nov 2021, 8:15 am | #6 |
Hello Ed
did you have any circuit info? Google searches draw a complete blank for this set, although its pretty simple I could probably get it going without a schematic. Cheers Andy |
12th Nov 2021, 8:45 pm | #7 |
Hi Andy, no schematics I'm afraid, but as you say it was a simple circuit.
A recap , one resistor gone high and I think one valve with an OC heater Ed |
14th Nov 2021, 3:31 pm | #8 |
Hello Ed
I've done the recap and changed the off value resistors. What impedance load did you connect to the output, and was there enough output to drive a loud speaker? I'm guessing it may want to drive 600 ohms? Cheers Andy |
14th Nov 2021, 9:06 pm | #9 |
Hi Andy, try a set of headphones that should be about right. Don't turn the wick up until you see how loud it is.
You may need a small transformer to operate a 3 ohm speaker as it may be 100v line for audio distribution ~ these transformers are readily available Ed |
15th Nov 2021, 6:36 pm | #10 |
Amazingly it works! The valve rectifier had to be replaced, but it provides a reasonable volume into a 600 ohm loudspeaker.
