View Poll Results: Will the radio work when turned on at 4PM? | |||
YES | 2 | 10.00% | |
NO | 18 | 90.00% | |
Voters: 20. You may not vote on this poll |
8th Dec 2021, 6:01 pm | #301 |
Re: Pilot Little Maestro pre war AC/DC 1939 restoration project.
Nice pic, but it would look a bit more "in use" if the pointer were vertical (tuned to Droitwich)
8th Dec 2021, 6:24 pm | #302 |
Video of the radio in action.
Thread can now be wrapped up mods.. Thanks again to all who helped out. https://www.youtube.com/watch?v=0W_ybqPj7zA
Help!! I've been electrocuted by a glass thing that glows |
8th Dec 2021, 7:30 pm | #303 |
Great to see [and hear] it working after all your efforts!
8th Dec 2021, 7:31 pm | #304 |
8th Dec 2021, 8:19 pm | #305 | |
9th Jan 2022, 3:10 pm | #306 |
Enough is Enough
It's that pesky little maestro again, In total it owes me around £70, Plugged it in today and the rectifier went pop And to make matters worse i just went and bought an audio output valve for it as the old one was giving a bit of distortion after warm up.
Time to retire it to the back of my wardrobe till i win the lottery
9th Jan 2022, 3:34 pm | #307 |
What rectifier is fitted? I have a few that might be suitable
9th Jan 2022, 3:37 pm | #308 |
25Z4G
Cheers for the offer sideband but its hit the limit of my cash outlay. Jay
9th Jan 2022, 3:39 pm | #309 |
Ok looking back through the threads, it has a 25Z4 fitted? I think I have a good one which I can check first. Yours f.o.c if any good to you.
9th Jan 2022, 3:45 pm | #310 |
Ok it's a 25Z4G. I'll check when next in the W/S. Before you change it, make sure nothing has failed that might cause the rec to fail. They don't normally just go pop! Failure mode is usually low emission but that takes time. They can go heater-cathode short which can be spectacular (in terms of what happens inside the rectifier).
9th Jan 2022, 3:47 pm | #311 | |
9th Jan 2022, 4:48 pm | #312 |
Dropper checks ok, So it must have been the heaters time to expire
9th Jan 2022, 5:05 pm | #313 |
Yes, the heater may have just expired.
However, the two 2uF capacitors in parallel that you used were Class X types and I think it was pointed out at some point in this thread that they can break down for very short periods and then self heal. This just might have caused the problem. Others have used a 4uF motor run (not motor start) capacitor in this application. |
9th Jan 2022, 6:19 pm | #314 | |
I've put a lot of hours on it recently, So think it might have just reached the end of the line
9th Jan 2022, 6:25 pm | #315 |
Anyhow I was just having a moan about the money and problems it's cost me If sideband can supply a rectifier then that would be very much appreciated
Can lock this thread for good now mods. Jay
29th Jan 2022, 2:41 pm | #316 |
Little maestro distortion
Been hesitant about posting this as everybody is probably sick hearing about it after the lengthy restoration thread
Anyhow a problem has developed and that is distortion after it's been on for a few hours. The distortion gets worse as the volume is decreased and better as the volume is increased, Iv'e tried swapping the audio output valve for a known good one but no improvement. My theory is the speaker as its not in the best nick and the voice coil is rubbing, Maybe its warping as the speaker heats up due to heat from the field coil. But i don't have another speaker so can't test my theory, Any ideas ? Cheers Jay
29th Jan 2022, 7:23 pm | #317 |
Well....if you keep the field coil in circuit and just disconnect the actual speaker connections, you can connect an ordinary speaker to the output transformer. When an energized speaker fails, it's quite normal to remove the field winding thus maintaining the HT and fit an ordinary PM speaker.
29th Jan 2022, 8:06 pm | #318 |
Was under the impression the field coil formed part of the mains filtering circuit, Or is that done by a hum bucking winding in the output transformer ? Also not sure of the speaker impedance.
29th Jan 2022, 8:17 pm | #319 |
Just unhook the wiring from the actual speaker's voice-coil and wire an external speaker in its place; you don't need to fret about the original speaker's impedance for a test - anything between 3 and 15 Ohms will work well-enough to show if the problem is with the speaker itself.
I'd check the standing current in the output-valve too - you could have some sort of leakage going on which is upsetting the bias; in times-past I have had the cheap-and-nasty paxolin-sheet valve-sockets start to break-down after 70-odd years and this can really confuse the valve's bias.
29th Jan 2022, 9:02 pm | #320 |
Don't think they would ever put mains through a field coil.....50Hz buzz! Some coils form part of the DC smoothing, others are connected across the HT. Either way, just follow the instructions by G6 above.....
