Old 30th Oct 2021, 2:23 pm   #21
60 oldjohn
Default Re: Electric clock c1900
Originally Posted by Lloyd 1985 View Post
This sounds similar to 2 Gibson Baume & co clocks I have here, they run from 4V, and every 2 minutes or so they go CLUNK and wind themselves up! In those clocks they have a basically normal spring wound movement, with contacts on an arm with 2 weights on it, when the spring winds down, the contacts fire the solenoid which flicks the arm and winds the spring, interesting to watch, and always makes people jump who aren’t expecting it!
Regards
Lloyd
Looking on the internet if found a photo like your yours. That is the nearest I could find to mine.
John.
My favourite text message "I'll be there in five minutes, if not read again"
60 oldjohn is offline
Old 30th Oct 2021, 2:28 pm   #22
60 oldjohn
Originally Posted by PJL View Post
A pendulum clock driven by a couple of small weights which sounds more accurate than spring wound as the force is more consistent and it lasts as long as the battery unlike the weights in a longcase.
I would agree with that.
On close inspection there are a lot of spare holes in the brass frame, and a plastic lug that rotates once a minute. I suspect it was originally a master clock, now with bits removed.
John.
Old 30th Oct 2021, 2:31 pm   #23
60 oldjohn
Originally Posted by Nickthedentist View Post
Thanks Nick, I will have a read.
John.
Old 30th Oct 2021, 2:38 pm   #24
60 oldjohn
Originally Posted by Refugee View Post
Here is a photo that shows much more clearly how an impuls clock works.
This one is actually an elapsed time indicator.
Same idea but yet another design. Is there just the one one winder? I presume the hole on the left is to hang a pendulum ? Thanks for sharing.
John.
Old 30th Oct 2021, 3:55 pm   #25
Mike Phelan
Mike Phelan's Avatar
Hi John,
It's not a Synchronome, Bulle, Murday or Lowne.
Mike.
Mike Phelan is offline
Old 30th Oct 2021, 9:36 pm   #26
60 oldjohn
Originally Posted by Mike Phelan View Post
Hi John,
Thank you Mike, I was hoping you could tell me what it is. If it helps the clock is from Ireland.
I will send you a PM.
John.
Old 31st Oct 2021, 2:19 am   #27
Refugee
Refugee's Avatar
John.
It is massively simpler than that.
It only has a single winder and the movement is more like a big wristwatch.
The main spring is the coil spring looped over the axle.
The "pendulum" hanger you have seen is one of the spade terminals for the power.
There is a much more complex elapsed time indicator in the background that would take us off topic. it is a very different movement. The case is on and does come off with an ask for another thread.
Refugee is offline
Old 31st Oct 2021, 11:28 am   #28
60 oldjohn
[QUOTE=Refugee;1419266][QUOTE=60 oldjohn;1419070]
Silly me, that "hole" for the pendulum looks the same as what we have here, I was going to ask what it was made out of because I am told it is more accurate if it has a small amount of movement, and the one here is not original. I'm sure someone on here will have come across a flexible pendulum hanger.
Thank you for the picture, maybe best not to go to another thread.
Meccano Man by any chance?
John.
Old 31st Oct 2021, 11:53 am   #29
Lloyd 1985
Lloyd 1985's Avatar
I think the part you are referring to is known as the pendulum suspension, loads available on eBay, but you would need to know the dimensions of the original part, but you might get away with one that ‘just fits’. It’s normally a thin bit of spring steel, sometimes with brass ends folded over it.
Regards
Lloyd
Lloyd 1985 is offline
Old 31st Oct 2021, 1:56 pm   #30
Refugee
Refugee's Avatar
John.
If a thread on elapsed time indicators is asked for I am pretty sure the moderators will allow it.
The one I showed is nice and simple so it is easy to see how it winds. It is very similar to the way a battery powered flip clock winds.
The other one is a different beast altogether hence a new thread if there is an interest.
Refugee is offline
Old 31st Oct 2021, 3:05 pm   #31
60 oldjohn
Regards
Lloyd
Thanks, I have just had a look and passed the link on to my friend.
John.
Old 31st Oct 2021, 3:08 pm   #32
60 oldjohn
John.
I would be interested as would a few others on this forum. Go for it.
John.
Old 31st Oct 2021, 9:53 pm   #33
PJL
Do the lantern pinions suggest it might not be UK? Perhaps USA?
PJL is offline
Old 1st Nov 2021, 4:01 am   #34
Refugee
Refugee's Avatar
John.
I have started the new thread.
https://www.vintage-radio.net/forum/...92#post1419592
Refugee is offline
Old 1st Nov 2021, 9:33 am   #35
Mike Phelan
Not necessarily so - plenty of them in UK.
Mike.
Old 13th Nov 2021, 1:09 pm   #36
6.3volts
6.3volts's Avatar
Nick your picture of the Rover clock has reminded me of how many car clocks worked. I have had many cars with these and none of them worked untill I sorted them. Usually dirty contacts.
6.3volts is offline
