Websites Found an interesting website? Post the details here and share it with the rest of us. Please stick to websites that are in some way related to our hobby/interest. |
16th Aug 2021, 4:55 pm | #1 |
Virtual Valve Museum
Does anyone know what has happened to this website of CV-numbered valves? All I get is a warning of an 'unsafe site'.
https://www.valvecollector.uk Andy |
16th Aug 2021, 5:08 pm | #2 |
Re: Virtual Valve Museum
Works fine for me (assuming I am looking at the same thing).
You are probably being protected from accessing a web site that might be dangerously interesting, due to some issue with certificates (or lack of them). When you see that stupid message try looking in the "advanced" bit for the details. It usually turns out that their certificate for HTTPS has just expired which I regard as a very minor security issue. |
16th Aug 2021, 6:57 pm | #3 |
If you're referring to what I've circled below it simply means the the site is using plain HTTP rather than the secure HTTPS protocol. Given that you'll only be viewing the site rather than entering any sensitive information into it I wouldn't (and don't) worry about it.
16th Aug 2021, 7:24 pm | #4 |
It was still misbehaving when accessed via my favourites bar, using either IE or Firefox. Going via Google to find the address https://www.valvecollector.uk it worked fine, so I have deleted it as a favourite and replaced it and it now works as it should. Very odd!
Andy |
16th Aug 2021, 8:16 pm | #5 |
Accessible here and showing secure site (padlock) seconds before I typed this message.
Lawrence. |
17th Aug 2021, 7:10 am | #6 |
I get this when using FireFox as my browser, Safari gets upset and thinks I am an imbosile for trying to look at an "unsecure" site. This message can easily be placed in a list of trusted sites.
No idea about microsoft.
Valve equipment repairs since 1968 https://jonsnell.co.uk Last edited by Radio Wrangler; 17th Aug 2021 at 9:03 am. Reason: OS wars remark removed |
17th Aug 2021, 8:48 am | #7 |
I see that a couple of replies here mention the 'r-type' valve museum website; this is not the same valve museum as the one I was discussing.
Andy |
17th Aug 2021, 8:57 am | #8 |
Perhaps you could supply a link to the valve museum you are discussing then.
17th Aug 2021, 9:46 am | #9 |
17th Aug 2021, 9:54 am | #10 |
Edited into first post.
17th Aug 2021, 10:30 am | #11 |
Still ok here a few minutes ago.
Lawrence. |
17th Aug 2021, 10:39 am | #12 |
As I said in post #4, it is also working OK for me now.
The problem was somehow associated with accessing it via my Favourites bar, but strangely using either IE or Firefox. Deleting it as a favourite and then re-entering the address cured the problem. Andy |
17th Aug 2021, 11:00 am | #13 |
That screen shot was taken using Windows 10/Edge, not used Firefox for years so can't comment on that.
Lawrence. |
17th Aug 2021, 11:54 am | #14 |
Odd. The server is set up to redirect http to https on first contact so there should never be an issue. Apache sends a 301 redirect so the browser should immediately go to the https page, unless browsers are beginning to look into and whinge about redirections before redirecting...
Edit: a thought, I wonder if an old page has some http: references inside. I thought I had got all of them but I will have another look. That would / should cause a warning. |
17th Aug 2021, 8:55 pm | #15 |
I use Brave most of the time and that site works just fine,...
...where on earth did that spring/screw go?? |
25th Aug 2021, 9:36 am | #16 |
both links in #1 & #4 work for me.
Mike |
2nd Sep 2021, 7:55 am | #17 |
Firefox version 92.0 beta, has no issues. Safari Version 15.0 is also fine.
Firefox is downloading a newer version and has to restart so I will let you know in a few moments. Firefox 92.0 full public version is also fine. Maybe the browser history needs clearing because it is looking for an out of date page.
Valve equipment repairs since 1968 https://jonsnell.co.uk Last edited by JonSnell; 2nd Sep 2021 at 7:57 am. Reason: More information added. |
