23rd Jan 2021, 4:29 pm | #21 |
Re: 1965 Mustang AM radio restoration. 5TMZ.
I think the positive ground nature of the transistor is taken care of by plastic membrane and lithium grease in between. The collector communicates with the rest of the radio through two screws and they are commented on the other side to a wire.
I did the test and wrote the result in a table. I'm not too sure how to interpret it. I think toast? (The end of first line means about one second values of about 1700 then drop to OL. The test did was using "diode" setting. |
23rd Jan 2021, 4:32 pm | #22 |
Photos
23rd Jan 2021, 4:34 pm | #23 |
You don't seem to be adding the attachments.
See Grahams guide Here https://www.vintage-radio.net/forum/...ad.php?t=77650 Cheers Mike T
23rd Jan 2021, 5:30 pm | #24 |
One more try to upload, this time lower res.
I heared the big can capacitator may also be culprit because "the electrolyte may dry out and make shorts. Did i do the measurements correctly? What is the verdict? |
23rd Jan 2021, 5:33 pm | #25 |
Did you test the C-B an B-E junctions both ways ie reverse the meter's leads? That would give four readings.
The case is the collector. https://pinout.net/element_browse.php?conid=16820
23rd Jan 2021, 5:49 pm | #26 |
I tested c to e, c to b, e to b
Both ways (change of polarity) - showed in all cases that pair of leads work as diode but between c and e this function got after about second OL reading. Isnt it wierd? Second: what are your thoughts on capacitator readings? I have heared two stories that it has something to do with filtering interference from alternator or with speaker signal amplification. If i got readings like 1; 2 or 92 Ohm against the casing of Capacitator does it mean its broken? Last edited by daveoverride; 23rd Jan 2021 at 6:00 pm. |
23rd Jan 2021, 5:50 pm | #27 | |
They were very reliable except for the 2SA72 transistors. I replaced all three with universal replacements, available at the time. I never found a shorted 2N176 or a bad output transformer. It was probably the early to mid-70's since I worked on one. Dave, USradcoll1 |
23rd Jan 2021, 5:53 pm | #28 |
Weird or not that transistor is open circuit and therefore useless.
23rd Jan 2021, 6:17 pm | #29 |
Ok that determines that the best way would be the TDA2030 as Chris suggested. I'll go ahead and order couple of units (in case of faliure or later needed).
Regarding the schematics of 5TMZ: If someone reading have them - please send me or someone from forum a photo. In case noone would have it i order it next week. |
28th Jan 2021, 11:25 am | #30 |
The TDA2030 board came and i have ordered shop manual of the radio, will post as soon as it arrives.
25th Feb 2021, 6:26 pm | #31 |
Any ideas what should i remove and where should i solder the amplifier board?
25th Feb 2021, 6:27 pm | #32 |
Schematics of the circut
26th Feb 2021, 12:06 pm | #33 |
Luckily (for ease of modding) the radio is negative earth so no odd signal grounds to contend with.
I'd disconnect the collectors of the audio transistors V4 and V5 to shut the audio stages down leaving the parts in place in case anyone might later go for a restoration rather than repair. Connect the power + and - to the amp module + to the switched 12V at point 2 and - to the chassis. Disconnect the + end of C17 from point 21 and connect it to the amp signal input. Connect the amp signal ground input to the slider of the tone control pot (this is signal ground). Disconnect the speaker output connector from the output transformer and ground and connect it to the speaker terminals of the amp. Cross your fingers! If no magic smoke released and sound is heard, adjust the input level trimmer on the amplifier to give a comfortable noise level when the radio volume control is set to mid travel. Go cruisin'
28th Feb 2021, 8:05 pm | #34 |
Hi, thanks for your quick answer.
No smoke came. I dont think it will be that easy... Just a reminder output transformer (what i guess it was - the bigest transf. Of all three) same as v5 are history (gone out of circuit). I conected: +12 to the vcc (Same)+ 12 to the circled 2 In to the disconected c12 + end (butchered it a little but no contact of coat to the middle metal part) First ground as read from left on amp board to the middle leg of potentiometer that changes volume (the correct knob that was changing Ohms as i turned it) The second ground to the case And speaker to the green crimp connectors ------- What it does is: Amp little red led is still ON, regardless of me turning volume knob all the way to off. Very faint hiss - only heareable when i lean to the speaker with my ear. |
28th Feb 2021, 8:12 pm | #35 |
Some photos
28th Feb 2021, 8:13 pm | #36 |
One thing to mention - i havent connected red-blue wire (which im sure is for front radio light bulb) and one other black wire that case and red enameled wire from a transformer on the left
28th Feb 2021, 10:14 pm | #37 |
Sounds like you've mixed up the slider of the tone control pot with that of the volume control pot for the signal ground connection. The slider of the tone control pot is connected to the anticlockwise (minimum volume) end of the volume control pot- I thought it might be easier to find a slider than one end of a pot since there's only one slider but two ends!
What are the actual labels for the pins on the amp module? I couldn't find any online info as to which was which for power +, power -, signal in and signal grouind.
1st Mar 2021, 11:29 am | #38 |
Hi Chris, I will check the tone / volume knobs once more, but i am pretty certain that when i turned the volume knob it was changing resistance measured with multimeter.
About the amp board VCC IN GND GND + - (out) |
1st Mar 2021, 11:35 am | #39 |
Regardless the faint hiss, i havent been able to tune into anything.
Secondly, isn't the current suppose to go through switch/volume knob prior getting to the anplifier board (fixing the amp ON while radio being OFF)? |
1st Mar 2021, 12:43 pm | #40 |
I think we're talking at cross purposes here- yes moving the volume control slider will vary the resistance between the slider and either end of the volume control but my query was about whether you had connected the signal GND input to the amp to the volume control or tone control slider. The former won't work since you would simply be shorting the volume control slider to ground via the amp, the latter is itself connected to signal ground in the radio and looked like a convenient easily identifiable physical point to connect the amp signal GND.
The amp signal IN is connected to the volume control slider, just via the capacitor C17. That's why I suggested disconnecting C17 from the base of V4 (point 22) first. I chose to do this to avoid any possible dc connection problems between the amp signal IN connection and the radio's signal circuits. If it's all connected up correctly and there's still no signal it looks like you will need to fault find the RF stages (to the left of the volume control in the circuit) next
