26th Jan 2021, 10:20 pm | #1 |
Garrard RC 121 mk ii always rejecting last record
Strange mechanical fault I cant seem to dig up an answer for elsewhere so seeking advice!
One of my players has a Garrard RC 121 mk ii which functions beautifully save for one very annoying fault. When a single record is placed on it for the auto cycle, or it reaches the last record of a stack, after the selector arm operates and the record drops, the selector arm swings into the center and trips so the tonearm (which has raised) goes into the stop cycle, lowers again and switches off. I've seen a few posts aiming to fix these players NOT functioning to stop and replaying the last record, but never this exact fault so am at a bit of a loss at to what is causing it. I'm used to using a Garrard 210, but I'm aware that the selector functions differently on that model and I'm pretty sure from what I've come across that once the selector has reached its position and the record has dropped it should stay in that position on a 121 mk ii. Can't bend my noggin around how it moves again to cause this. I should probably mention that when a stack is in place (thereby stopping it swinging into the center) it seems to try but a gentle click sounds suggesting the physical stopping of it disengages something. Any help gratefully received! -Antonia |
27th Jan 2021, 10:55 am | #2 |
Re: Garrard RC 121 mk ii always rejecting last record
Are you quite sure the Overarm is firmly seated over the stack of records? Make sure it is securely pushed down.
Edward. |
27th Jan 2021, 11:40 am | #3 |
Hi Edward thank you for replying!
It definitely is, and as this occurs when the last record has dropped it has sunk down to its lowest. |
27th Jan 2021, 7:30 pm | #4 |
When the size selector swings across to the edge of a record, it should give a slight "kickback" before the record is dropped. Is it doing that?
Barry |
27th Jan 2021, 7:30 pm | #5 |
On this series of decks the last record and the size is determined by a third arm. The overarm has nothing whatsoever to do with it.
27th Jan 2021, 8:05 pm | #6 | |
Thank you for replying! |
27th Jan 2021, 8:06 pm | #7 | |
27th Jan 2021, 10:08 pm | #8 |
One common fault is that the third arm cannot easily go to the centre due to it partially seizing on its pivot.
To rectify it, you'll have to strip it down. the manual which is on this site will help you. Locate the pick up cam (item 61) and remove it. That cam is located on a shaft, there are other bits that rotate on that shaft deeper in the mechanism. They all have to be removed, the shaft and all other parts thoroughly cleaned of old grease and then fresh grease applied before re-assembling. I'm not very good at explaining unfortunately. |
27th Jan 2021, 11:27 pm | #9 | ||
Barry |
28th Jan 2021, 3:41 am | #10 |
Thank you all for the replies - I'll look forward to browsing the manual as suggested Michael, and also for your reply Barry as I've noticed when it comes to these you seem to be regarded as "THE" go-to chap!
-Antonia |
28th Jan 2021, 9:07 pm | #11 |
I've been looking at the RC121 today, and all I can tell you is this. (I seem to have mislaid my service sheet). When the size arm comes across it touches the edge of the record, (any size), then kicks back about maybe an eighth of an inch, before moving in again to touch the edge of the record. This seems to "lock" the size arm into position, as after the record has dropped, you cannot push the size arm in or out any further until the arm has lifted at the end of the record. The "kickback" happens very quickly and has to be carefully watched for. I'm pretty sure the fault lies in the position of the size arm at the point where it hits the record, but can't be certain, unfortunately.
Barry |
28th Jan 2021, 9:44 pm | #12 |
Thank you Barry! That certainly gives me a very specific area to work on eliminating a bunch of other problems - I shall poke about at it more tomorrow and post if I have any luck!
-Antonia |
