Old 25th Apr 2021, 4:30 pm   #1
moomaloo
Default K6 phone booth help needed
Good afternoon all. I’m trying to find the dimensions of the hardwood door surround for a K6 ‘Jubilee’ phone kiosk. I have the cast iron window frame insert and have long thought of making a timber surround for it so that it looks more like a phone box door.
Try as I might and short of driving around the countryside tape measure in hand, I can’t find the dimensions... Just the external dimensions of the timber door surround would do it (as I can work out the internal dimensions from the window frame).
Any clues?
moomaloo is offline
Old 25th Apr 2021, 6:36 pm   #2
Default Re: K6 phone booth help needed
Measure and add 1/8th of an inch all round?
Old 26th Apr 2021, 7:51 am   #3
Electronpusher0
There is a red phone box without a door lying in a field near me, sounds like it should be married to your door.
If you are interested I can ask the land owner if he wants to part with it.
Peter
Electronpusher0 is offline
Old 27th Apr 2021, 3:49 pm   #4
steve102
I've attached an extract from Drawing 60905 which gives the dimensions of the hardwood door frame.
steve102 is online now
Old 27th Apr 2021, 4:30 pm   #5
I got the wrong door frame, I thought door lining. I love the proper drawing from steve102, teak isn't cheap.
Old 12th May 2021, 4:19 pm   #6
moomaloo
Folks!
I’m sorry for my silence. I signed up for email alerts and didn’t receive any so I assumed no replies... Silly mistake.
Thanks for all your help and advice and I’m now quite well along with the project. - Though I’ve abandoned the hardwood door surround as too expensive and am now using CLS timber, cut to the appropriate size (or as near as damn it) and painted to match.
I’ve just received a replacement handle but I’m disappointed to find that it appears to be silver painted mild steel (or cast metal) and not of the quality or finish that I expected. So if anyone has a spare genuine door handle...! (And this one was sold as genuine).
The box without a door lying in a field is tempting but I think I have enough to be getting on with!
Thanks again.
moomaloo is offline
Old 12th May 2021, 4:44 pm   #7
What is CLS?
Old 12th May 2021, 7:40 pm   #8
Cobaltblue
Cobaltblue's Avatar
Originally Posted by merlinmaxwell View Post
What is CLS?
Canadian Lumber Standard.
It's the sort of timber commonly used for studwork.
Mike T
Mike T BVWS member.
www.cossor.co.uk
Cobaltblue is online now
Old 12th May 2021, 8:24 pm   #9
Philips210
Hi.
Yes CLS timber very good for studwork and other projects. I've just finished building a small workshop with 3x2 CLS (actual size 63 x 38mm). It has the great advantage of having rounded corners and generally well planed to minimise the risk of splinters. Just ordered some more to build a sturdy workbench for the workshop.
Symon
Philips210 is online now
Old 12th May 2021, 8:42 pm   #10
Nickthedentist
Nickthedentist's Avatar
It's also amqzingly cheap for what it is!
Nickthedentist is online now
Old 12th May 2021, 9:47 pm   #11
Oldcodger
Found on FB
https://www.facebook.com/Red-Telepho...28634855485800
Also on FB in groups ( either Openreach (BT/GPO) Friends or Ex BT people ) there a few blokes who's hobby is K6 boxes.
Oldcodger is offline
