30th Jan 2006, 6:58 pm | #1 |
'The Editor' tape recorder
One of my yet to start projects (along with far too many others) is a restoration of an early tape recorder known as 'The Editor'. Looking through old magazines shows these being sold in the fifties through a mail order company. There were several versions and this looks like an early 50s one - they got a little less 'prototype' looking later on! The deck is a three motor job with a heavy cast flywheel and a pinch roller you have to engage manually. The whole deck is assembled on a piece of laminated chipboard. Erase and Rec/Play heads are by Lane and in cast alloy pots. I remember my father buying it secondhand and in need of repair in the early - mid sixties and he paid a pound for it! It's probably not worth that much more today but it is a curious piece of history, representing the kind of product that was sold to satisfy a boom market at the time and when a top consumer brand like Grundig could only be considered by the 'well off'
Has anyone come across one of these or remembers them? I'll post some pictures if anyone is interested. |
30th Jan 2006, 11:26 pm | #2 |
Re: 'The Editor' tape recorder
Hello, always interested to see some pics, it soulnd like my Truvox
https://www.vintage-radio.net/forum/...ead.php?t=7052 Must admit I have not heard of this machine and would be very interested seeing it. |
30th Jan 2006, 11:28 pm | #3 |
Yes , I would like to see a couple of pics of your recorder. Seeing them may jog my memory {Almost nonexistent now } The name "Editor" sounds familiar though.Can you show pics of the underside as well if possible.. I like the older recorders and wouldnt mind the little "Sound Belle" on Ebay at present.Also I would like a "Elpico Geloso", Every time I bid on one it goes for more than I can afford Or want to pay!! Peter [Reelguy}
31st Jan 2006, 3:01 am | #4 |
Is it either of these? Mick |
31st Jan 2006, 9:07 am | #5 | |
I found the construction quite unbelievable! The flywheel was a big lu,p of brass and probably worth more in scrap value.
Mike. |
31st Jan 2006, 9:59 am | #6 | |
31st Jan 2006, 10:01 am | #7 | |
Steve |
31st Jan 2006, 10:03 am | #8 | |
Steve |
31st Jan 2006, 2:18 pm | #9 |
The recorder does look very interesting from the ales literature, it would be nice to see some inside pics as well.
31st Jan 2006, 7:01 pm | #10 |
Steve,
You have a PM. Mick |
31st Jan 2006, 8:20 pm | #11 | |
The steel frame that the two chassis and the top deck bolt to means that the outer wooden case is just the cladding and unstressed. It might have been a 'utility' product but some good engineering went into its construction Steve |
31st Jan 2006, 8:33 pm | #12 | |
If I had, I could have retired! There were a few Walters as well - nowt special, but I quite liked them. Better than the Fidelity et al and all the other cheapies with BSR decks. The Editors I dealt with had a lot of bits of bent wire on the brake mechanism - like an American striking clock! I suspect these were the later ones that Mick has the sheet for.
Mike. |
31st Jan 2006, 8:38 pm | #13 |
Here are some photographs of "The Editor" tape recorder. It's quite grubby but will clean up quite nicely - a bit like a Formica work surface really! I have all the knobs and the pinch roller kept in a safe place - I just need to remember where that safe place was. The same goes for the microphone.
Steve |
1st Feb 2006, 7:05 am | #14 |
Does this machine not have a pinch roller?
2nd Feb 2006, 4:36 pm | #15 |
Laminated Chipboard for the deck!. Haven't come across that before, but it seems to have lasted well. Hope you get it going ok. I assume you have tapes to try on it? Peter {Reelguy}
4th Feb 2006, 10:40 am | #16 | |
Steve |
18th Feb 2006, 9:11 pm | #17 |
Hi Steve,
I Had one of the Editors as your pic. (original) back in the early 50's, spent more time repairing/modifying than using, best of luck, at least will keep you warm in Winter. Doffery |
18th Feb 2006, 11:25 pm | #18 |
I forgot ! I was going to send a PM to you as I saw one of these going for sale...somewhere... it was in real nice condition, don't know if it sold though and have not been able to trace it nut where you have the two audio connectors at the top of the machine there should be a chrome ring, shame about the chipped surface.
22nd Feb 2006, 10:20 pm | #19 |
Looks like the motors were made by Collaro, they'll probably need stripping down and relubricating
