24th Mar 2023, 3:43 pm | #21 |
Re: Punch data for the SD4 Tetrode-Diode Valve
The only available curve for the SD4 gives the anode current for –2.0 V GB as 9.0 mA, and very happily Keith Thrower's Valve Data Book gives the VP13C data as 200 V anode for a current of 9.0 mA @ –2.0 V GB, for which Card 206 has been issued, so it looks like we need Card 206 for the voltage and current punch data!
24th Mar 2023, 3:47 pm | #22 |
Thanks Chris for your continued help, much appreciated.
24th Mar 2023, 6:31 pm | #23 |
I'll dig out Cards 149 and 206 tomorrow and issue a revised punch list!
Chris Williams
24th Mar 2023, 6:41 pm | #24 |
So all together, we need a combination of :–
Card 149 for the heater data ; Card 157B & C for the diode connections punch data ; Card 200 for the Anode Voltage, Anode Current and Grid Volts Data ; The card for the valve isted in Base no. 8 on the B7 Valveholder Connections Chart from the "Wireless World Valve Data Book", 1961 Version! Chris Williams
25th Mar 2023, 6:57 pm | #25 |
Chris, I have reposted my proposed Tetrode card here. The table on the top right has the card hole positions 1-10 as the top row, the corresponding pins for each socket are shown below.
As mentioned in the other thread, The Dutch version of the SD4 is an E444 with a B6 base whatever that is. The AVO data does have an E444 Va=200, Vs=90V, Vg=-3, ia=4mA, gm=3mA/V but there is also an E444N which is the same except Va=100V. The datasheet included in the other thread for Va=200, Vs=100, Vg=-3 would give ia=7mA so I would be inclined to set the test conditions for Vg=-4V and set it so that 2mA is the pass line. |
26th Mar 2023, 7:37 am | #26 |
So where are we with this? Do we have a consensus for the cards' design or still in disagreement? I'm not in any rush, just trying to mediate! Cheers.
26th Mar 2023, 9:49 am | #27 |
The Diode card based on the TDD4.
26th Mar 2023, 5:56 pm | #28 |
If we cannot reach total consensus and end up with 2 versions of the Tetrode I will punch both and let Steve decide which he prefers.
Peter |
26th Mar 2023, 6:14 pm | #29 | |
If anyone has a NOS SD4 or a known very good one that we could borrow then that would be excellent. Lots of care taken and all expenses paid of course. Chris, PJL, would a PM exchange between you guys help to reach a consensus?
26th Mar 2023, 6:52 pm | #30 |
No guarantees with my cards, I wrote the calculator program in 2006 so long since forgotten the details although I do use it quite often and it seems to work reliably although I did spot a minor issue as B10 (the B row is normally for sg) is used to earth the top cap rather than assign it to sg.
To avoid damaging a valve, you can check a card by simply measuring the voltages on the relevant socket pins without a valve and switched to position 6 . |
26th Mar 2023, 9:12 pm | #31 |
Chris, this is your project and I have been interfering with it, so I will leave the final decision to you. Feel free to ask any questions as I did spend many many hours analysing the circuit to produce the program and age can't have taken it all?.
28th Mar 2023, 2:33 am | #32 |
I'll double check the exact wiring of the valveholders between contacts 1 to 9 on rails A to E, logically, Mullard would have wired Contacts A1, to the valveholder pins 1 etc., but as Peter rightly suggests, Mullard could have done it in a different order, for reasons only known to themselves, for the EL84 (card 635) for example, Peter's replacement card has hole A5 punched and not A7 as would be suggested by the EL84 valve base connections, so even possible that like pins on each valve–holder are not necessarily commoned to the same contact, so me thinks I need to get a new diagram started, and we can work it out from there for definite!
Matters aren't helped by me not being able to locate a tetrode or pentode valve with a basing that corresponds to base No. 8 in the "B7" chart in "Wireless World's" Valve Data book yet! I definitely would like to know why hole A5 is punched on the EL84 card and not A7 tho', I shall have to see if I can find out when I can get my only battery multimeter repaired! Chris Williams
It's an enigma, that's what it is! This thing's not fixed because it doesn't want to be fixed! Last edited by Chris55000; 28th Mar 2023 at 2:47 am. |
28th Mar 2023, 7:20 am | #33 |
Thanks Chris. No rush, take your time.
6th Apr 2023, 8:03 pm | #34 |
Chris, are you able to comment further? Cheers.
8th Apr 2023, 1:16 am | #35 |
Still tracing out the valveholder wiring diagram of my unit and until I finish this it's difficult to add anything further at this stage!
Chris Williams
8th Apr 2023, 8:23 am | #36 |
No worries Chris, thanks for the update.
8th Apr 2023, 4:46 pm | #37 |
I'm still on standby to make the card.
Peter |
8th Apr 2023, 4:57 pm | #38 |
Thanks Peter. I'd rather wait for this to be sorted out than have to make multiple attempts and waste your time. Ok, it may need a couple of attempts, but ideally it would be nice to get it right first time for everyone's sake.
23rd Apr 2023, 5:16 pm | #39 |
How's investigations going Chris? any luck?
24th Jul 2023, 6:33 pm | #40 |
I'm still interested in having this card made (and I suspect others too would like such a card), is it possible to achieve a consensus on the card parameters for Peter to work from?
