Old 18th Dec 2009, 12:11 am   #41
stevekendal
stevekendal's Avatar
Default Re: Really bad warping
All good sound advice thanks guys, but seeing as I spend too much time at the day job, I'm going to just leave the reconstructed cabinet in a warm room for a few days and then if all is well, I have plenty of veneer somewhere, walnut and zebrano no less! Steve.
Knobs and tubes rule ok
stevekendal is offline
Old 18th Dec 2009, 9:33 am   #42
chipp1968
chipp1968's Avatar
presumably if the top has expanded its due to having soaked up the moisture you gave it while clamping flat , presumably this will shrink again. Keep it away from the radiators or too much heat . best if it does it slowly
chipp1968 is offline
Old 20th Dec 2009, 7:53 pm   #43
stevekendal
Right, now with fingers in ears and egg on face, things arent looking too rosey The newly attached top has lifted again at the back, but only by a couple of mil so far. I could live with that, but I think theres probably worse to come. Its pretty well stuck down now with PVA, so do I just leave it and let it slowly come apart at the back, or should I ask Santa for a circular saw so that I can cut it off and make the new top that I should have done earlier? Steve.
Old 20th Dec 2009, 8:41 pm   #44
Colin
Colin's Avatar
Steve, just an idea, but could you remove the whole piece of veneer from the top (this may not be possible by now of you've used PVA on it) and using a router, circular saw, hand saw or drill, make a series of cuts/holes such that the panel can be straightened without it being under any tension. There would be no need to go right through the panel so the inside face would remain intact and undamaged.
A mixture of sawdust and glue can be used to make the straightened panel rigid again and then the veneer can be re-glued. If the edges are damaged in this process they could be repaired with filler and paint.
I've seen this technique used to bend skirting boards around rounded corners in bay windows etc. It may be easier than making a new panel from scratch.
rgds
Colin
Colin Armstrong
Colin is offline
