Old 20th Aug 2005, 6:20 pm   #1
Woody
Default Cleaning Of cabinet Coverings.
What is the best way of cleaning the vinyl like covering on radio and record-player (etc) cabinets ?.
Last edited by Darren-UK; 5th Jun 2007 at 11:15 pm. Reason: Wording made more appropriate.
Woody is offline
Old 20th Aug 2005, 10:38 pm   #2
Darren-UK
Default Re: Cleaning Of Box Coverings
If you're just talking about plain old dirt, we are looking at warm, soapy water with a soft cloth and an old toothbrush for those awkward corners, or hard surface foam cleaner, or simply a good furniture polish and a soft cloth.
Paint spots will wipe off with persistence and a damp cloth if it's emulsion - which it usually is.
Some points to mention are:
1. Take care of any liquids getting into/onto any of the electrics.
2. Warm water can soften the glue which affixes the vinyl/rexine.
3. Don't rub/scrub too hard as this may remove the dye and leave 'bald' areas.
Darren-UK is offline
Old 24th Aug 2005, 1:13 pm   #3
Neil Purling
The Ferguson I have bought is filthy and I was wondering about using the foaming cleaner. Whether it would lift the dirt out without harming the surface of the vinyl? Any favoured products?
Neil Purling is offline
Old 24th Aug 2005, 1:45 pm   #4
paulsherwin
paulsherwin's Avatar
I've found the bathroom foaming cleaners to be fine on most surfaces - you can even use them to clean speaker fabric if you're careful. The foam cleaners designed for kitchen use are more caustic and I wouldn't use those.
Best regards, Paul
Last edited by Darren-UK; 5th Jun 2007 at 11:11 pm. Reason: Out-of-date retail price reference removed.
paulsherwin is offline
Old 24th Aug 2005, 7:00 pm   #5
Neil Purling
Well, first I was going to dust the case to remove what is loose, using a dry paint brush & tooth brush for the corners.
Since I am working on a record player I have to work on the mechanics & electronics before I see to the finishing touches.
Last edited by Darren-UK; 5th Jun 2007 at 11:10 pm. Reason: Out-of-date retail price reference removed.
