23rd Jun 2009, 10:06 pm | #1 |
Decals / Transfers for a HMV
Gents,
Attached is a photo of the original decal that's on top of the HMV set I've recently bought. The transfer's in pretty good order, but the rest of the cabinet needs some work. Do you know whether these decals available? Or has anyone got a digitised version that could be printed onto water slide transfer perhaps? Any advice would be welcome. I'm a bit reluctant to sand it off, but it will look a little odd if the rest of the cabinet is nicely re-finished and there is a square with the transfer on it that's been left alone! Thanks! Andy |
23rd Jun 2009, 11:28 pm | #2 |
Re: Decals / Transfers for a HMV
Andy,
I had a similar problem, and ended up scanning a speaker to capture the image, then cleaning up the image (at the pixel level!) with MS Paint. It took a lot of work, but the results worked well printed onto waterslide paper. (I've attached my cleaned-up image in case it's of any use to readers of this thread). dave
Dave Teague |
24th Jun 2009, 1:35 pm | #3 |
Great work, Dave!
But I would try to save your original, Andy. Does your set really need stripping? Could you post a picture of it? Original finishes can often be revived, and your set would look nicer for it. Have a look at the recent thread about restoring a finish on a KB console. Nick. |
24th Jun 2009, 5:19 pm | #4 |
Here's another one I've been using. The HMV transfer is a problem because you really need to make a combination of an opaque transfer (for the central box) and a transparent (for the letters) transfer. One way to do this is to create a transparent one using Lazertran paper and then add an opaque one of the box, on top. But you'll need to experiment with various 'darknesses' out of your printer to get a good result for both the letters and the box.
These transfers used to be available commercially - I've got one of them on my restored HMV 469, but I don't know who might still have them. Steve
https://www.radiocraft.co.uk |
24th Jun 2009, 6:30 pm | #5 |
Hi Andy,
I really like your original transfer. Is there any possibility you could sit the cabinet on a scanner and email a scan of it to me? Regards David |
24th Jun 2009, 6:53 pm | #6 | |
Of course if we're talking major veneer loss and/or woodworm damage..... Andy |
24th Jun 2009, 7:46 pm | #7 |
I remember marconi and HMV transfers available 20 years ago . I need one for my HMV tV ,but yours has more to it .It may be saveable . piccy please
24th Jun 2009, 8:12 pm | #8 |
Chaps,
Thanks for your help - Dave & Panrock - excellent work on the digitally re-made versions! I was thinking the same thing re: scanning the original before doing anything, the problem I have at the moment is that my scanner glass is not flush with the surrounding plastic - as a result I can't get the scanning surface close enough to the transfer to get a decent scan. I will perservere though - I'm sure I can find someone with an appropriate scanner! Attached are a few photos of the cabinet. You're right that the cabinet may well respond well to a good clean up; however the finish is that typical thinly laquered type, which chips easily. I'm not too sure how to go about improving that, but I'll check out the thread you mentioned. Thanks for your help! Andy |
24th Jun 2009, 10:37 pm | #9 |
Andy,
Perhaps I'm not being pedantic enough, but it looks splendid from a distance. I'm with the camp that says can you work round it? Alan |
25th Jun 2009, 12:48 am | #10 |
Andy,
My first impressions are that your original finish is saveable Let's see what the others have to say. Nick. |
25th Jun 2009, 7:52 am | #11 |
I'm with the "it looks ok to me group"..If it were mine I'd give it a touch up with one of these products,(others are available!).At least the label is on the glass dial and will come off easily.
Dave G1AGK. My perception is my reality! |
25th Jun 2009, 8:21 am | #12 |
I agree that it looks like it will revive with good results.You will always see some marks but they will be toned down .It s worth the effort and in fact is less effort than stripping and re finishing ,which will never look as original unless done proff , even the roughest strip and refinish would be harder effort than the revive especially if all the scratches are like the ones you have shown and the finish is like that all over, not turning to powder.
25th Jun 2009, 10:49 am | #13 |
Hi Andy,
You should also consider the problems with making this transfer. As Panrock mentioned earlier, you need a mix of transparent and white opaque backgrounds. My method would be to use two transparent waterslides and paint the relevant areas with white paint on one and then lay the other one top. It sounds easy, but it's not and looking at all the 'floating' lettering, it might even be impossible!.... It's still worth scanning for posterity though Like everyone else I think you should try and keep its finish. Everybody has their own opinion on this, but this is how I would proceed
David |
25th Jun 2009, 1:58 pm | #14 | |
Steve
26th Jun 2009, 1:17 pm | #15 |
Chaps - I'll give it a go!
I bought some burnishing creme (which I guess is pretty similar to T-Cut) and I've got plenty of Danish oil so will see how that combination works out! Thanks for your advice Andy |
26th Jun 2009, 9:00 pm | #16 |
Good ! remember you may need to colour some scratches to hide them before the oil is applied
OH and dont rub the decal too hard with anything in case it rubs away |
26th Jun 2009, 10:21 pm | #17 |
Clean with white spirit. Apply boiling (very hot) linseed oil and rub hard and quick before it cools. This trick will remove minor crazing and recover the gloss finish where matt surprisingly well.
Danish oil will not bond too well with cellulose laquer. |
29th Jun 2009, 8:33 pm | #18 |
Hi Andy, A while ago there was a short article in the "Bulletin" which suggested using nothing more than old fashioned liquid paraffin. I couldn't believe the result and ended up going over lots of our woodwork with it including solid mahogany kitchen units. Liquid paraffin took a lot of finding but it is readily available at about £1 per bottle from Asda Pharmacies. Good luck, Col.
