Old 13th Jun 2009, 9:01 pm   #1
colinpost
Default some black inlay missing
On my HMV 482 wood case, i've got a couple of inches of black inlay missing. I was thinking of usiny expoxy resin (dyed wih black cement dye), but read that this could shrink.
On the other hand, someone had suggested to use superglue, which would shows no sign of shrinkage.
Anyone have any thoughts or other suggestions ?
colinpost is offline
Old 13th Jun 2009, 9:34 pm   #2
Radio_Dave
Radio_Dave's Avatar
Default Re: some black inlay missing
I'm not sure what your trying to repair, but I would suggest you start with something a little less permanent in case something goes wrong.
What about melting black wax crayon into the void?
Radio_Dave is offline
Old 13th Jun 2009, 9:54 pm   #3
colinpost
the inlay is 3mm wide an 3mm depth and there a two sections (30mm) missing.
i'll try and post a photo
Old 14th Jun 2009, 9:16 am   #4
yesnaby
yesnaby's Avatar
Hello,
You can get 3.4 mm square ebony stringing - quite cheap but the postage is a bit much. Maybe someone has a bit lying around? Could easily be sanded down to 3 mm square.
http://www.originalmarquetry.co.uk/c...tringing_1.htm
Michael
yesnaby is offline
Old 14th Jun 2009, 7:13 pm   #5
chipp1968
chipp1968's Avatar
you should attempt at replacing it with wood veneer if poss. Stringing is available , but is useually quite narrow ,or decorative . is it actually black ? if so you will need a very close grained wood , that you then have to dye . you can get small packs of veneer too .
chipp1968 is offline
