31st May 2009, 6:11 pm | #1 |
"Pertrix" grid bias battery label scans
Gents,
For those of you who might be wishing to re-label something resembling a grid bias battery in an old set, please find the scans attached! Note that these are very much reduced in size; if you'd like the original scans, which are at 600dpi resolution, PM me and I'll send them through. Cheers Andy |
31st May 2009, 9:33 pm | #2 |
Re: "Pertrix" grid bias battery label scans
Very nice. Is it 9V only or are there taps? What are the dimensions?
2nd Jun 2009, 7:23 pm | #3 |
There were several taps on the original battery, can't quite remember them all (the battery was disposed of; it was a leaky mess!) but think there might have been taps for 1.5, 3, 4.5, 7 and 9v.
Dimensions were approx 12cm wide by 7cm tall, and about 1.5 cm thick. I found it when I took the back off a very early valve set (pic attached) that I recovered from a manor house in Lincs, about 20 years ago! |
2nd Jun 2009, 10:09 pm | #4 |
Not likely to be a 7 volt tap . 6 & 7.5 would be possible, though.
Chris |
