28th Jun 2008, 12:31 pm | #21 |
Re: Is Superglue OK for this......?
How long can Superglue be left before heating ceases to have an effect - if ever? I fixed our teapot-lid with it a while back, and I can't say I've felt any ill-effects, but it's always at the back of my mind that it might not have been the best adhesive for the job!
Regds, Russell W. B. G4YLI. |
28th Jun 2008, 12:45 pm | #22 |
Unreliable, at least they were some years ago. We tried using similar to retain wiring looms in domestic electrical equipment. For no apparent reason, they would come off and when one wanted to get one off, Sod's Law of course, they were stuck really fast! Infuriating
28th Jun 2008, 1:56 pm | #23 |
The problem with sticky pads is they act like a "slow liquid" i.e. they hold solidly against vibration, but try hanging a coat off one of those hooks they used to sell in Wilko's and sure enough, after a while, the hook would fall off! Same experience using them to retain cable looms, we used to use them at my old works for commercial chargers used in the mining industry!! Not that any harm would result in the looms coming loose but that's not the point
Reliability of such pads has probably improved though and they are certainly fine for attaching items to surfaces if there is no significant (continuous) mechanical loading. I have a few programmers & card readers attached to my computer desk using these and they are still stuck fast after a year or so BG |
28th Jun 2008, 5:29 pm | #24 |
Unibond No More Nails double sided sticky tape. And no I am not a Unibond sales rep though maybe I should be.
Or good old fashioned Evostick like that poured over small pocket radios inards to keep everything in place. Geof |
29th Jun 2008, 6:47 am | #25 | |
Takling of tea, it is time for an early morning cuppa Geof |
29th Jun 2008, 8:43 am | #26 |
I didn't know where it would lead when I started this thread.....!!!
29th Jun 2008, 12:04 pm | #27 | |
Al. |
29th Jun 2008, 1:20 pm | #28 |
My two cents...
I would agree with GMB & use silicone rubber sealant. It's an excellent insulator & because it's flexible it won't stress solder joints when the assembly heats up, unlike hard setting epoxy. Mark. |
29th Jun 2008, 6:34 pm | #29 |
I would be inclined to agree with the silicone for this job, regardless of the horrid smell.. somewhat worse than araldite IMHO
About ceramics. I once broke my mothers teapot tile that was used to protect the melamine at home. I glued it up with ordinary PVA white wood glue, the reasoning being it claimed to stick wood and porous materials, and it was all I had around. I still have the repaired tile 20 years later. It sits under my kettle serving pretty much the same function. So for ceramics like teapot lids, cup handles etc. it's worth a try. It will take a stain as well, so you could probably make an approximate colour match to whatever you are repairing. Oh and the lodger cracked the toilet seat right across.. ceramic-like plastic.. similar in texture to broken bakelite... Same stuff, this time the modern "no more nails" version. Has lasted 12 months and counting. |
29th Jun 2008, 7:34 pm | #30 |
Hi, i use a glue stick melted with a soldering iron for that type of job.
Malc Scott |
29th Jun 2008, 8:49 pm | #31 | |
Certainly covering a broad range of applications |
29th Jun 2008, 9:29 pm | #32 |
The 'vinegar smell' is acetic acid which will attack copper & cause it to corrode.
Al. |
30th Jun 2008, 4:49 pm | #33 |
Ahhh.. I have only encountered the bathroom variety, but I have found that good for sticking odd things to odd things where nothing else seemed to work.
Thanks for the eye opener about the acetic acid content.. It made me think of an alternative use for possibly using it to strip corrosion from copper chassis? I must experiment some time. |
30th Jun 2008, 6:04 pm | #34 |
The so called "low modulus" sealant is the non-acetic kind. It is available in most DIY shops. Typically used as a sanitary sealer or for other building use.
The bath-seal type products are the high modulus acetic curing type. |
