Old 3rd May 2005, 12:13 pm   #1
G0PKH - Pete
G0PKH - Pete's Avatar
Default DAC90A Tuning calibration label
Hi all.
Picked up a very cheap 90A a while ago (another one! ) which I am restoring.
Has anyone got a scan or a reproduction of the green calibration label which is usually stuck on the back of the dial assembly ?.
I wouldn't normally go to this extreme with one of these, but the rest of chassis is in such excellent condition, that it seems a shame not to replace the label.
Thanks
Pete
G0PKH - Pete is offline
Old 3rd May 2005, 4:31 pm   #2
Darren-UK
Default Re: DAC90A Tuning calibration label
Hi Pete,
If it's of any use to you, I've just scanned the attached image from the actual Bush service sheet. Maybe you can make a new one using this info.
Darren-UK is offline
Old 3rd May 2005, 6:50 pm   #3
Cerberos
I am working on a DAC90A at the minute (still doesn't work).
Here are a couple of shots of the label with a ruler in shot. Should enable you to make you're own.
Might be easier if the ruler were in inches not millimeters but I am sure there is enough info to be able to make a label.
ID:	591   Click image for larger version
Cerberos is offline
Old 3rd May 2005, 7:38 pm   #4
Radio_Dave
Radio_Dave's Avatar
Hi
Due to the fact that that I've go nothing better to do , I've re-worked the photo that Cerberos has posted. It's a little difficult to work out the exact dimensions but I have done my best. The finished print needs to be 8.35cm in length
HTH
Radio_Dave is offline
Old 4th May 2005, 12:36 pm   #5
G0PKH - Pete
Hi all.
Well what can I say .
Many thanks to all, and especially to David for the finished article.
Now just to find a suitable backing for the label .
Must try to find some clear inkjet labels big enough.
Cerberos
Good luck with your 90A I hope the chassis is not as rusty as the tuning slide looks,seems you have your hands full there
Thanks chaps.
Pete
Old 20th May 2005, 1:07 pm   #6
G0PKH - Pete
Thanks all.
Thanks to the image that David provided, I have now reproduced a fairly acceptable label using the self adhesive clear film I purchased (see my other thread regarding the Hacker Silver Knight).
As this label is fairly small the result is quite acceptible, although It would not really be suitable for a much larger decal, the print quality is not very good on this film, I am still trying a number of different print options.
Pete
