27th Jan 2020, 1:31 pm | #1 |
Location: London, UK. Bury, Lancashire quite regularly :)
Black crackle or crinkle finish.
Hi.
I have recently acquired an AVO Test Bridge, the meter movement dates it to 10/47. This one is the second iteration using a 6B8G and no Westector. It was in pretty decent condition when I received it, and looks even better after a good clean. It appears original inside. However. The sheet metal case into which it fits has suffered paint loss in a couple of places which mars the appearance somewhat. The finish is a tight black crinkle. Q. Is it still possible to obtain paint to replicate this finish? Thanks in advance for any insight
Thermionic Emission, warms the cockles of your tubes. |
27th Jan 2020, 1:42 pm | #2 |
Re: Black crackle or crinkle finish.
It's used on the dashboards of 50s/60s MG cars, and is available from Frost.
https://www.frost.co.uk/vht-black-wrinkle-finish-310ml/ |
30th Jan 2020, 1:36 pm | #3 |
Thank you for that, appreciated.
18th Mar 2020, 3:56 am | #4 |
Some of the wrinkle/ crackle finishes I have used here in the U.S. have required "curing" in the oven at 200 deg.F, others do not.
Be sure to check the paint type you buy. |
