Old 26th Jan 2020, 6:45 pm   #1
its ur aerial
its ur aerial's Avatar
Default Bush Radio transfers
Does any one know of a supply source of Bush Radio logo Transfers that can be applied to a restored wooden cabinet of a 1950`s Radio
Ken G6HZG
Life is not Hollywood, life is Cricklewood.
its ur aerial is offline
Old 26th Jan 2020, 7:38 pm   #2
John10b
Default Re: Bush Radio transfers
I may have one left over in the shed, if it’s the one you want let me know and you can have it. David Decatron made them some time age.
John
John10b is offline
Old 26th Jan 2020, 7:44 pm   #3
its ur aerial
That will be fine, I can send you my contact details on a private message.
Ken G6HZG
Old 26th Jan 2020, 9:05 pm   #4
David G4EBT
David G4EBT's Avatar
I made some a couple of years ago and offered them on the forum in strips of four.
I still have four strips left, as depicted below.
If anyone would like a strip, they're £2.00 inc post.
As anyone will know who has tried, applying waterslide transfers - ('decals' as they're known outside the UK) - is an acquired skill. You must not slide the transfer off the backing paper as it will wrinkle up. You must place the transfer in position still on the backing paper and gently slide the backing paper from beneath the transfer, while smoothing the transfer onto the cabinet. It helps in adjusting the transfer to get it exactly right, to apply a little soapy water to the cabinet.
They adhere really well once dry and are quite durable.
Hope that helps.
Name:	Bush waterslide set top logo strip of four..png
David.
BVWS Member.
G-QRP Club member 1339.
David G4EBT is offline
Old 26th Jan 2020, 9:42 pm   #5
David G4EBT
One strip gone - three left.
David.
BVWS Member.
Old 26th Jan 2020, 10:25 pm   #6
John10b
Hi Ken, it was David G4ETB who supplied me, I’ll have a look in my shed tomorrow I may have one left,and get back to you ok.
Of course you can contact David.
John
John10b is offline
Old 26th Jan 2020, 10:28 pm   #7
John10b
Hi David, they work well, see my picture I attached.
John
John10b is offline
Old 26th Jan 2020, 11:46 pm   #8
David G4EBT
John
Thanks for the thumbs up John.
Two strips left now.
David.
BVWS Member.
Old 27th Jan 2020, 8:16 am   #9
mervyn
Hi David
yes please if there are any left
regards
Merv
mervyn is offline
Old 27th Jan 2020, 8:23 am   #10
David G4EBT
Originally Posted by mervyn View Post
Hi David
regards
Merv
Please PM me your postal name and address and I’ll get a strip off to you Mervyn.
Just one strip left now. I’ll reserve it for now In case Ken, the O.P might need it.
(He’s not logged into the forum since before I mention that I had some).
David.
BVWS Member.
Old 27th Jan 2020, 11:07 am   #11
John10b
Hi Ken, yes I do have two transfers which are surplus to my requirements which you can have. Just pm me.
These were originally obtained from David so you may prefer to buy a set from David it’s up to you.
John
John10b is offline
Old 1st Feb 2020, 12:21 pm   #12
John10b
Hi Ken, I presume you have obtained the transfers from David? No problem just wondered.
John
John10b is offline
Old 5th Feb 2020, 9:03 pm   #13
its ur aerial
Yes got them thanks, all sorted.
Ken, G6HZG.
Old 6th Feb 2020, 8:59 am   #14
Kevin Hoyland
Hello.
Morning to all. David sent me the transferes. They are outstanding.
Thank You David.
Kevin
Kevin Hoyland is offline
