29th Jul 2019, 3:45 pm | #21 |
Re: Traditional Paint Stripper.
What is wrong with using the even-more traditional method of "blowlamp-and-paint-scraper, followed by varying grades of glasspaper?
Just a thought.... Colin. |
29th Jul 2019, 4:48 pm | #22 |
It requires a modicum of practice to acquire the skill to loosen the paint just right without scorching the surface underneath. With old paint there's also lead fumes to get excited about
29th Jul 2019, 6:52 pm | #23 | |
In fairness, most who bemoan the non-availability of Dichloromethane (Methylene Chloride) to untrained domestic users (myself included), probably haven't tried the stuff that is now available - I certainly haven't, and such criticism as I've read, which has been extensive, tend to widely held anecdotal views that nothing works as good as Methylene Chloride. Looking at the favourable reviews of Wilco's stripper, there are examples (including a picture) of it having been used to strip paint off ceramic tiles in a bathroom, and stripping seven coats of paint off bannisters. I shudder to think of anyone using methylene chloride for indoor uses such as that. It's illegal for trained professionals to do that nowadays, let alone DIYers. When my last dregs of Paramose runs out, I think I'll be heading for Wilko!
29th Jul 2019, 7:08 pm | #24 |
Location: London, UK. Bury, Lancashire quite regularly :)
Thanks for all the help / insight / comments.
It's varnish on a vintage radio woodie that needs removing - it's too far gone. It was only when I realised the Nitromors (had it sitting in a cupboard for ages) was virtually exhausted that I discovered it had become unobtainium (cue much rude language...) I certainly don't fancy my (very limited) skills with a blowlamp; I know how that would end. I have actually purchased some Wilko stripper (having bowed to the apparently inevitable, i.e. I ain't getting any of the old stuff,) we'll see how it goes.
Thermionic Emission, warms the cockles of your tubes. |
29th Jul 2019, 7:37 pm | #25 |
A while back I needed to strip an Eddystone cabinet and found that the "Diall" branded stuff from B&Q worked surprisingly well, though it was a _lot_ slower than classic Methyl Chloride Nitromors, and didn't give that nice "crinkling" effect that really let you know it was working.
https://www.diy.com/departments/b-q-.../262263_BQ.prd |
30th Jul 2019, 4:16 am | #26 |
Langlow Strip Away Pro is the real deal, a proper methylene chloride paint stripper. It's quite readily available if you do a little searching online.
Regards, Richard Last edited by YoungManGW; 30th Jul 2019 at 4:23 am. |
30th Jul 2019, 9:18 am | #27 |
For veneered or fine solid wood I use Liberon Fine Wood Stripper https://www.liberon.co.uk/product/fine-wood-stripper/
It takes a time to work, and is nothing like as aggressive as methylene chloride. But for a veneered radio cabinet, that would be my choice. I always have a can on the workshop shelf. I buy it locally from https://www.toolpost.co.uk/product/l...tripper-500-ml . Craig |
30th Jul 2019, 11:14 am | #28 | |
May I continue to be a bit pedantic on this topic? The solvent which has been banned is methylene dichloride, or methylene chloride. Methyl chloride isn't the same - it is related to chloroform, which is trichloromethane and only has one carbon atom, as opposed to methylene dichloride which contains two carbon atoms and two chlorine atoms. I wouldn't mind betting that all of the methyl- and methylene- chloride compounds are controlled in some fashion. Probably all of the fluoro- and chloroflouro- compounds, too. I appreciate that it may not matter much to many on this forum, but correct nomenclature may prevent errors, or worse. Colin. |
30th Jul 2019, 1:58 pm | #29 | |
'Ride at your own risk'. Here's what the manufactures of Langlows Strip Away Pro - Palace Chemicals - say about it, which also explains why non-Methylene Chloride water-based strippers are not so effective with some types of paint coatings: Quote: It is uniquely effective in removing specialised industrial paints such as two-pack epoxy coatings, cellulose lacquers, traffic paints and powder coatings which are not as easy to remove using less volatile water-based paint stripping products. Note: Operators using this product must have received full training and be competent in the use of control systems both engineered and for personal protection from exposure to vapour levels above the workplace exposure limit for Methylene Chloride. Restricted to industrial use and to professionals approved in certain EU Member States – verify where use is allowed. • Contains Methylene Chloride • The fastest acting Paint Stripper available • For use only by trained operators • Rapid blistering & penetration of coatings • Effective on industrial & two-pack coatings • Will remove automotive paints End quote. https://palacechemicals.co.uk/shop/l...away-pro-copy/ They did make a Langlows Strip Away Product called Strip 'n Lift' for non-professional use, which is now discontinued, which they state is: • Non-flammable • Non-methylene chloride • Water based low VOC • Blisters and softens paint layers • Clings to vertical surfaces They now do a 'paste on' Strip Away for non-professional use which sounds a bit of a faff as it has to be pasted on and a special polyethylene and fibrous tissue applied over it till the paint has emulsified. Its active ingredient is Sodium Hydroxide (caustic soda) - a powerful alkali. It claims to strip up to 30 layers of paint, but doubtless it depends on what type of paint. They state that a 12 kg pack should be sufficient to cover approximately 3.3 square metres at the maximum 3mm spreading rate, and 10 square metres at the minimum 1mm spreading rate. At £102.98 inc VAT (£31 per sq M), I won't be in the queue to buy it any time soon! https://www.decoratingdirect.co.uk/viewprod/p/PALPA1/ Hmmmm.
30th Jul 2019, 4:31 pm | #30 |
In my experience B&Q paint stripper is useless.
30th Jul 2019, 5:09 pm | #31 |
When i was making large PU mouldings the pressurised nozzles delivering and pre-mixing the two compounds required had to be flushed afterwards with DCM. This did not concern me too much until I contemplated the extraction gear, which consisted of a fan, attached to some ducting, which was poked out of an open casement window. The PU mouldings were cured by water running thro' the mould at 60C, and the room therefore had an ambient of about 38C. Polish Pete worried me further when he removed the gloves that we used for protection at the end of the shift, dropped them in the waste bucket and poured some DCM on them. They bubbled up and slowly disintegrated as we watched.
This wasn't in the sixties, this was round about year 2000. Even the smell of DCM now makes me nervous! I am glad it's restricted. Dave |
30th Jul 2019, 6:02 pm | #32 |
30th Jul 2019, 6:14 pm | #33 | |
Methyl chloride = chloromethane = CH_3Cl (1 carbon, 3 hydrogen, 1 chlorine atom) Methylene chloride = dichloromethane = CH_2Cl_2 (1 carbon, 2 hydrogen, 2 chlorine atoms). Chloroform = trichloromethane = CHCl_3 Carbon tetrachloride ('Carbon Tet') = tetrachloromethane = CCl_4 |
30th Jul 2019, 8:42 pm | #34 |
I refer back to post#8. The paint stripper I use is "useless" B&Q. It strips anything if you have a modicum of patience. I've used it on furniture, radio cabinets, gramophone cabinets etc. No lifting of veneer, inlay, banding or my skin. Personally I consider waiting overnight a small price to pay if, when my grandchildren reach my age there are still fish in the rivers, bees, butterflies and hedgehogs in the garden and birds in the air.
30th Jul 2019, 9:09 pm | #35 |
B&Q stripper wouldn't touch the painted boarding on my house - much of which was already peeling. I used plenty of patience thank you. Put copious amounts on and it did barely softened the surface before the mess dried out. It might have done the job if I'd have bought a tanker-full and perhaps tipped the house on its back.
Eventually I resorted to a blowtorch and a scraper - what the environmental impact of this is/was I'm not sure. |
30th Jul 2019, 11:15 pm | #36 | |
I don't know whether a myth has been built up about the awesomeness of the original Nitromors. It did not strip all paints - some were quite resistant to it. I'm always amazed that some paints are untouched by acetone and methyl ethyl ketone (MEK). Used brake fluid has been touted (a glycol?) but that is very slow. OK for old recovering paint brushes? Re Wilko's product, there's no safety data sheet for it on the net so its constituents are unknown. The Wickes' stuff, which I like, is (IIRC) benzyl alcohol which does not seem to set off any safety or environmental alarm-bells. It has virtually no odour and has not produced any irritation when I've got it on my skin. It comes as a gloopy liquid, which clings nicely to vertical surfaces. Again, some paints resist it very well. B
31st Jul 2019, 1:21 am | #37 |
A brake fluid that used to be good for stripping paint was Castrol Girling Crimson, but this seems to have been unavailable for a couple of decades since the change from drum brakes to disc brakes required higher performance fluids. I used to use it for stripping oil paint from polystyrene models, but the later stuff did virtually nothing.
31st Jul 2019, 9:05 am | #38 |
Strange... I've tried the same stuff and found it to be utterly useless. After about four hours of sitting on the surface it lightly softened the top layer of paint (probably four or five layers of old paint altogether) but barely enough to scrape it off. Niotromors used to liquify thick layers of paint within minutes!
31st Jul 2019, 10:32 am | #39 | |
Paints have different formulas/ingredients so I'd heard. I'm not a chemist. Substrates/interface types/conditions vary. You can still buy rose tinted glasses but be aware the genuine antique ones are worth more to some. If I wanted some paint stripper these days I'd just go to B&Q or Screwfix and give it a go. That methylwhateveritis seems to be nasty stuff. Lawrence. Last edited by ms660; 31st Jul 2019 at 10:40 am. |
31st Jul 2019, 10:49 am | #40 | ||
YoungManGW, my "correction" wasn't aimed at you, but at G6Tanuki, who did use the name Methyl Chloride. Apologies for the confusion and thanks to Tony for the erudite correction. Perhaps I should go and get my coat.... Colin. |
