Old 21st Nov 2005, 9:00 pm   #1
Ian G4HJM
Default Spire Nuts, removal of.
Ferranti U1003,
The wooden panel on to which the loudspeaker is fixed is attached to the main cabinet with several of these rectangular push-on fasteners. Whats the best method of removal without wrecking the cabinet ?
regards
Ian
Ian G4HJM is offline
Old 21st Nov 2005, 9:24 pm   #2
Sean Williams
Sean Williams's Avatar
Default Re: Push on fixings -- removal ?
I use a very fine screwdriver, or a pair of needle nose pliers, and gently ease the small teeth back - the clip then falls off.
To refit you just need to squeeze the teeth back down, and push onto the stud with a nut runner.
Sean
Sean Williams is offline
Old 21st Nov 2005, 9:47 pm   #3
Nickthedentist
Nickthedentist's Avatar
That's exactly what I do, but you make it sound so easy, Sean. I find them a real PITA!
Nick.
Nickthedentist is offline
Old 21st Nov 2005, 9:58 pm   #4
Sometimes it's possible to thread two lengths of thin strong wire under the lugs. Pulling on the two loops formed will then often allow the 'spire nut' to be pulled off.
Another method is to grip the sides of the nut with pliers and screw it off by turning and pulling.
Graham.
Station X is offline
Old 21st Nov 2005, 11:43 pm   #5
Paul Stenning
Administrator
Paul Stenning's Avatar
That's how I normally remove them. You just have to be careful not to snap the post off. Some sets have pairs of posts so if one does snap you can put the clip on the adjacent one.
Paul Stenning
Paul Stenning is online now
Old 22nd Nov 2005, 1:55 am   #6
paulsherwin
paulsherwin's Avatar
As Paul says, it's very difficult not to snap the plastic posts. The fact that there are often 2 posts suggests the makers didn't expect anybody to remove these successfully - you can disassemble once, then that's it
When the post breaks the clip will fly through the air and it's easy to lose it.
I managed to break *all* the posts securing the speaker in my KB MR10, and had to fabricate new fastenings from long nuts and Araldite.
Good luck, Paul
paulsherwin is online now
Old 22nd Nov 2005, 12:12 pm   #7
Sam
Sam's Avatar
Some of the things I have which use those fasteners have a post with two flats on it. You can then give the clips a quarter-turn so the clip then slides off the post.
Sam
Can he lead a Normal life, Doctor?
No, he will be ... an Engineer.
Sam is offline
Old 22nd Nov 2005, 5:51 pm   #8
Mike Phelan
Mike Phelan's Avatar
I either use iron binding wire from a florist, or push a cheap pair of tweezers under the lugs.
Mike.
Mike Phelan is offline
Old 23rd Nov 2005, 7:10 pm   #9
Ian G4HJM
Thanks all for suggestions.
I tried the pulling with fine wire technique first, result was the easy removal of four out of five fasteners. The last one seems to have been pushed really firmly up to the wooden board and the two little clips have bitten deeply into the post.
In the end I snapped the post, but as suggested, there is an adjacent unused post; so all is not lost. !
Again, many thanks for all those very helpful suggestions.
regards
Ian
