Old 20th Feb 2005, 10:44 am   #1
Mike Phelan
Mike Phelan's Avatar
Default Mallory-Plessey cans
Hi fellow avocados
Just successfully managed to recreate a couple of 1930s cans for my 378 project, thanks to Rejectostat for supplying the text and a local aluminium stockholder for some offcuts of tube and bar for a few beer tokens.
I have put the cans that Jim Beacon gave me 'into stock' for a later project.
Mike.
Mike Phelan is offline
Old 20th Feb 2005, 11:22 am   #2
Nickthedentist
Nickthedentist's Avatar
Default Re: Mallory-Plessey cans
Nice work!
How did you join everything together? And what did you print the text on to?
Nick
Nickthedentist is offline
Old 20th Feb 2005, 12:56 pm   #3
Mike Phelan
Originally Posted by Nickthedentist
Nice work!
Nick
Hi Nick
The 'can' is alloy tube - I turned an alloy plug for each end - the top one is a tight fit, and is Araldited in as well.
The bottom one is a sliding fit, and is retained by a 6 BA countersunk screw. It has a 3/4 inch x 16 TPI thread in it, into which the nylon stub screws, and is retained by a touch of Araldite. I haven't made the nuts yet - today's job!
I have pictures of the internal construction, but they are over 100k, so cannot attach them here. Screwcutting on nylon is not easy, because it tries to deform instead of accepting a cut - a case of making a very shallow cut each pass. I could got some alloy, but wanted to use what was in my scrapbox.
The text was printed on to waterslide transfer paper with an inkjet printer. This is available from http://www.craftycomputerpaper.co.uk/index2.htm and works extremely well.
HTH
Mike.
Old 20th Feb 2005, 1:30 pm   #4
Paul Stenning
Administrator
Paul Stenning's Avatar
Originally Posted by Mike Phelan
....but they are over 100k, so cannot attach them here.
Zip them and attach the ZIP file. ZIP files can be up to 1MB.
Paul Stenning
Paul Stenning is online now
Old 20th Feb 2005, 2:39 pm   #5
Steve_Bell
I have made new cans for a Philips radio with similar fixing. I had problems too trying to cut threads onto plastic so I used the main body of a nylon cable gland, adapting it to fit into the bottom of my can and gluing in place. I then used the flat nut supplied for fixng the can in its hole. These glands come in M13, M16, M20 thread sizes from Maplin.
Steve_Bell is online now
Old 20th Feb 2005, 3:48 pm   #6
Mike Phelan
Ah - thanks, Paul - didn't realise there was a higher limit (probably because I have failed to read something here )
Mike.
Old 20th Feb 2005, 3:51 pm   #7
Mike Phelan
Here is a .ZIP of the full story of the cans!!
Mike.
