26th Jan 2020, 6:45 pm | #1 |
Bush Radio transfers
Does any one know of a supply source of Bush Radio logo Transfers that can be applied to a restored wooden cabinet of a 1950`s Radio
Ken G6HZG
Life is not Hollywood, life is Cricklewood. |
26th Jan 2020, 7:38 pm | #2 |
Re: Bush Radio transfers
I may have one left over in the shed, if it’s the one you want let me know and you can have it. David Decatron made them some time age.
John |
26th Jan 2020, 7:44 pm | #3 |
That will be fine, I can send you my contact details on a private message.
Ken G6HZG
26th Jan 2020, 9:05 pm | #4 |
I made some a couple of years ago and offered them on the forum in strips of four.
I still have four strips left, as depicted below. If anyone would like a strip, they're £2.00 inc post. As anyone will know who has tried, applying waterslide transfers - ('decals' as they're known outside the UK) - is an acquired skill. You must not slide the transfer off the backing paper as it will wrinkle up. You must place the transfer in position still on the backing paper and gently slide the backing paper from beneath the transfer, while smoothing the transfer onto the cabinet. It helps in adjusting the transfer to get it exactly right, to apply a little soapy water to the cabinet. They adhere really well once dry and are quite durable. Hope that helps.
26th Jan 2020, 9:42 pm | #5 |
One strip gone - three left.
26th Jan 2020, 10:25 pm | #6 |
Hi Ken, it was David G4ETB who supplied me, I’ll have a look in my shed tomorrow I may have one left,and get back to you ok.
Of course you can contact David. John |
26th Jan 2020, 10:28 pm | #7 |
Hi David, they work well, see my picture I attached.
John |
26th Jan 2020, 11:46 pm | #8 |
Thanks for the thumbs up John.
Two strips left now.
27th Jan 2020, 8:16 am | #9 |
Hi David
yes please if there are any left regards Merv |
27th Jan 2020, 8:23 am | #10 |
Please PM me your postal name and address and I’ll get a strip off to you Mervyn.
Just one strip left now. I’ll reserve it for now In case Ken, the O.P might need it. (He’s not logged into the forum since before I mention that I had some).
David. BVWS Member. G-QRP Club member 1339. Last edited by David G4EBT; 27th Jan 2020 at 8:30 am. |
27th Jan 2020, 11:07 am | #11 |
Hi Ken, yes I do have two transfers which are surplus to my requirements which you can have. Just pm me.
These were originally obtained from David so you may prefer to buy a set from David it’s up to you. John |
1st Feb 2020, 12:21 pm | #12 |
Hi Ken, I presume you have obtained the transfers from David? No problem just wondered.
John |
5th Feb 2020, 9:03 pm | #13 |
Yes got them thanks, all sorted.
Ken, G6HZG.
6th Feb 2020, 8:59 am | #14 |
Hello.
Morning to all. David sent me the transferes. They are outstanding. Thank You David. Kevin |
