4th Oct 2015, 8:58 pm | #1 |
Location: Al-Kharj near Riyadh, Kingdom of Saudi Arabia.
Help with National NV-780EM VHS
the problem in this video when i press vtr
its turn on for a second and off. the clock working what the problem ... |
5th Oct 2015, 12:50 am | #2 |
Re: Help with National NV-780EM VHS
Sorry don't know the model but would suggest worth checking the power supply for bad capacitors. Very common on some Panasonic units. Just a starting point maybe others can elaborate.
5th Oct 2015, 2:19 am | #3 |
i think it is not in the power
i have another power it's the same problem |
5th Oct 2015, 4:54 pm | #4 |
Not sure if this model has automatic power-up when inserting a tape, but worth trying if it has. Also check the VTR switch isn't sticky or damaged; clean the mode switch; check for dry solder joints.
Regards, John |
6th Oct 2015, 2:26 pm | #5 |
I have the service manual for this machine. This model has a switching power supply since it is 110-240 volt automatic. And it is a multi system too.
6th Oct 2015, 2:41 pm | #6 |
Try heating the power supply with a hair dryer. If the situation improves while it is hot, it has bad capacitors for sure. If the situation doesn't improve, it can still be anything.
6th Oct 2015, 4:40 pm | #7 |
When you press the operate button can you hear the capstan motor rotating?
7th Oct 2015, 12:15 am | #8 |
Yes
7th Oct 2015, 9:32 am | #9 |
When the capstan rotates check if the supply reel table also rotate
8th Oct 2015, 7:45 am | #10 |
Yes
8th Oct 2015, 9:39 am | #11 |
The second display below the deck (function display) works ok
8th Oct 2015, 9:04 pm | #12 |
Yes work but shut down in second the clock still working
8th Oct 2015, 9:49 pm | #13 |
Check the zener diode and the caps in the switching power supply.
9th Oct 2015, 4:19 pm | #14 |
Check the All Voltage in the PSU.
You need Schematic and SM of this VTR, to check the voltage's are coeherent with the schematic. Libra |
9th Oct 2015, 10:34 pm | #15 |
This is a relatively early front loader from the mid 80s. D deck.
If it's the one I'm thinking of, it has a transformer PSU. On powerup, the mech should 'shuffle' the reel idler. If this doesn't happen, then the drive belts should be replaced and the mode switch cleaned. That shoud solve this fault. There was also a resistor of very low ohms/safety type, that used to go high, cannot recall if it was in the PSU or on the main PCB where the voltage lines come in. Will try and find some info.
Regards, Ben. |
10th Oct 2015, 1:51 am | #16 |
I think that one is on the main PCB. At least in the NV-830 and NV-850 which may be related models. R1001 or something close to that comes to mind.
10th Oct 2015, 11:10 pm | #17 |
You can download the service manual from here
http://freeservicemanuals.info/en/se...sonic/NV780EM/ These type of panasonic/national mechanism (D1) when the VCR operates the mechanism proceed a <<selftest>> the capstan motor rotate the suplly reel table and the loading motor make a small movement (rotation). if the self test find a failure the VCR rotate for a few seconds the capstan or the loading motor (it depends from the failure) and then turn OFF. |
11th Oct 2015, 3:05 pm | #18 |
I believe the person who the machine belongs to has tried another power supply and still has the same fault?
12th Oct 2015, 1:11 am | #19 |
thank you all
I will do everything |
14th Oct 2015, 4:28 pm | #20 |
My money is on the mode switch being faulty or having dirty contacts.
I had a lot of trouble with this series not doing its switch-on 'shuffle' and then shutting down due to the mode switch having dirty contacts. Tony |
