Old 5th Jun 2021, 11:46 am   #1
saddlestone-man
Default Control-C, etc
Hello All
When I'm using any editor I still tend to use Cntrl-C (Copy), Cntrl-X (Cut), Cntrl-V (Paste), Cntrl-F (Find), etc.
Does anyone know when/where these commands originated?
best regards ... Stef
saddlestone-man is offline   Reply With Quote
Old 5th Jun 2021, 12:13 pm   #2
Default Re: Control-C, etc
I suspect they date back to the original DOS-days of Wordstar, Borland Sidekick and suchlike.
Old 5th Jun 2021, 12:19 pm   #3
paulsherwin
paulsherwin's Avatar
They are old Windows shortcuts. They may have been influenced by the Wordstar word processor under CP/M and DOS. (Posts crossed.)
They are certainly not universal commands. Ctrl-C is a process interrupt command on many OSs including Linux.
paulsherwin is online now   Reply With Quote
Old 5th Jun 2021, 12:38 pm   #4
duncanlowe
The use of Control (Ctrl) commands is much earlier in general though. For example I believe Ctrl-B was the Bell command from when terminals actually had a bell, later the terminals would beep for Ctrl-B.
Edit: sorry Ctrl-G was bell.
duncanlowe is offline   Reply With Quote
Old 5th Jun 2021, 1:24 pm   #5
AC/HL
AC/HL's Avatar
I also use those instinctively. There are many more, P for print etc.
Bill, BVWS member
Old 5th Jun 2021, 1:55 pm   #6
Malcolm G6ANZ
Malcolm G6ANZ's Avatar
It was Larry Tesler who invented ctrl c and ctrl v etc
https://www.cbc.ca/news/science/tesl...obit-1.5470453
Malcolm
Malcolm G6ANZ is online now   Reply With Quote
Old 5th Jun 2021, 2:44 pm   #7
Control-J was the bell on early (Baudot) Teleprinters, I think. Which pre-dates computers.
Old 5th Jun 2021, 3:04 pm   #8
paulsherwin
Malcolm
Xerox PARC was massively important in the development of modern desktop computing, which is odd for a company which was primarily a photocopier manufacturer. Both Windows and the Mac interface were pretty much stolen from Xerox designs, and they also developed Ethernet, initially as a fast interface for their high end laser printers.
https://en.wikipedia.org/wiki/PARC_(company)
Old 5th Jun 2021, 3:14 pm   #9
TonyDuell
The PC use of the control codes is totally different from their original ASCII meaning, where, for example Ctrl-C is ETX (end of text). Ctrl-G was BEL (ring the bell) in ASCII, on things like the Teletype Model 33 it mechanically rang a little bell inside. On the electronic Teletype 43 there was a solenoid-operated bell (and as a total aside, on the DEC VT5x series of terminals like the well-know VT52, the keyclick was produced by a little relay on one of the boards, the bell consisted of feeding a square wave to this relay so that it buzzed).
There is no control in baudot/murray code (both techincally incorrect names for ITA2). The figure shift of J rang the bell though (or closed a pair of contacts to operate an electric bell)
I seem to remember the early Apple Macintosh machines had 'command' key, often called 'splat' due to the symbol on it, and command-C was cut, command-V was paste, etc. I think Windows simply copied the same letters. But it's been a long time since I used such a machine.
TonyDuell is online now   Reply With Quote
Old 5th Jun 2021, 7:37 pm   #10
cliff2903
I think this has been on here before, maybe useful
https://support.microsoft.com/en-us/...6-cb9706c75eec
cliff2903 is offline   Reply With Quote
Old 5th Jun 2021, 9:50 pm   #11
saddlestone-man
Very interesting information, many thanks.
How about Cntrl-Alt-Del as a way of getting out of an application quickly, or to re-boot the OS. Was this a DOS invention?
Old 6th Jun 2021, 3:54 am   #12
TonyDuell
Ctrl-Alt-Del is picked up by the ROM BIOS keyboard driver of the very first PC (IBM 5150) and effectively causes a reset (look at the routine at address EA71 in the BIOS listing of the PC Techref on bitsavers, page 367 of the .pdf).
Since the 'Alt' key was not common on microcomputers before the 5150, I am pretty sure that was the first machine to use Ctrl-Alt-Del.
Old 10th Jun 2021, 8:49 pm   #13
Slothie
In the "Wild west" days of software, there were no real standards. In ~1987 IBM releases the "Common User Access" or CUA standard which I remember being given when I worked at a software house in the late 80s, and detailed standard menu layouts, keyboard shortcuts etc for its SAA (System Application Architecture) and this applied to all IBM Operating systems including OS/2 and Windows applications. It was widely adopted by other manufacturers. The keyboard shortcuts were derived based on what other popular systems did (including the work of Larry Tesla as pointed out by Malcolm above). Things like F1 for help and F2 for save were common tropes for software from a number of vendors. It is speculated that IBM drew from the Apple User Interface guidelines that were released a few years earlier and I beleive were based on the research of Xerox and their smalltalk operating system. So its kind of a twisted path, but the major influences over the years ultimately have been Microsoft and Apple who standrdised things across all their OS's and applications and so software developers followed suit.
Slothie is online now   Reply With Quote
Old 11th Jun 2021, 1:33 am   #14
arjoll
arjoll's Avatar
The equivalent on the Apple IIe was Ctrl-Open Apple-Reset. I'd never used a II and only once touched a II Europlus, but apparently on those models Reset alone performed the same function.
arjoll is offline   Reply With Quote
Old 11th Jun 2021, 3:37 am   #15
TonyDuell
On the Apple ][ and Europlus the 'reset' key is connected in hardware to the reset circuit for the processor. It is not trapped in software like ctrl-alt-del on the IBM PC. This is true of most older machines, reset is a hardware function, no matter what the software is doing, it will work. On the IBM PC, if the processor is not responding to interrupts, then ctrl-alt-del will do nothing.
As an aside, on later Apple ][ machines there was a slide switch on the keyboard encoder board that gated the reset key with the control key so you had to press the 2 together to get a reset. Again done in hardware. I will have to look in the technical reference manual to see what the //e does.
Old 13th Jun 2021, 3:27 pm   #16
TonyDuell
I've looked in the Apple //e technical reference manual (a hardback book...) and alas while it contains the circuit diagrams for the various types of motherboard, it does not include diagrams of the keyboard PCB itself. However the reset pin of the 6502 (etc) processor is connected to the keyboard connector and the manual does state that the reset key does not return a keycode, it directly resets the processor when pressed along with <ctrl>. The open-apple and closed-apple keys are sensed by being connected to a couple of input port lines (the 'games port' inputs on the Apple ][), I've not bothered to read through the ROM source in said manual to see what they do.
If anyone really wants to know what the reset key does I can dig out my //e, take it apart and trace out the reset section of the keyboard pcb. But only if it's essential.
Old 13th Jun 2021, 4:31 pm   #17
I remember some of the early SUN servers where sending a _long-break_ from the console would drop things into single-user mode.
Cue a certain RS232 reverse-terminal-server being installed to allow a rack of Suns to be remotely consoled-to over TCP/IP from a single VT100-session on your laptop.
Alas, if you power-cycled this thing it sent a long-break.... to every connected device....
Old 13th Jun 2021, 7:06 pm   #18
Slothie
I remember being at a computer show, and there was a guy selling little boxes to go over the Apple ][ reset button (which was precariously close to the return key). To reset the computer you had to remove the box to press the button!
Old 14th Jun 2021, 4:12 am   #19
TonyDuell
Some time back I worked on a Computest unit, I mentioned it here. One puzzle I had was that the reset key (which like other machines of a similar vintage provides a hardware reset to the processor) seemed to do nothing.
It turned out there's a bit of logic on the keyboard PCB includng a monostable with a period of a couple of seconds. You have to hold the reset key down until the monostable times out for there to be a reset. Release it before that and nothing happens. This struck me as a rather neat way to protect against accidentally hitting the reset key.
Old 14th Jun 2021, 7:09 pm   #20
wireman
That must have been very very early because I remember a break or L1-A would put you into the PROM and I started with the Sun4 SPARC era.
wireman is offline   Reply With Quote
