Hints, Tips and Solutions (Do NOT post requests for help here) If you have any useful general hints and tips for vintage technology repair and restoration, please share them here. PLEASE DO NOT POST REQUESTS FOR HELP HERE! |
18th Jan 2008, 7:52 pm | #1 |
Cleaning brass etc
I am restoring a Marconiphone T14A which has a brass speaker grille.This was absolutely filthy and tarnished. I tried all the usual cleaners, Brasso, etc. without any success. I "Googled", brass cleaner and came up with Quiksilver, on eBay. This plate, when used with soda crystals, boiling water and Persil non bio, should clean brass. I was sceptical, but decided to give it a try. Much to my surprise, it worked. When I dropped the grille into the solution, the plate seemed to effervesce and lo and behold clean, shiny brass. I haven't tried it on other metals, but is supposed also to clean silver, copper, gold, bronze and stainless steel. Does anyone know how or why this system seems to work?
19th Jan 2008, 7:44 pm | #2 |
Re: Cleaning brass etc
Most of the muck is probably of a biological nature or oxidation of the brass so the Persil soap will remove the grime, and the soda acts as an agitator.
I have used Cillit Bang on raw brass, no hot water or soda needed, I don't know how it would work on other metals. And it shouldn't be used on plated surfaces, which could include silver. Geof |
20th Jan 2008, 12:01 am | #3 |
Hi.
When I clean up brass or copper engine parts I use Nitric acid (just drop it in for 2 or 3 seconds) it is no good if you require a shiny finish and it is pretty nasty stuff (do not breathe in the fumes). It is great for cleaning stuff prior to welding. Daniel. |
20th Jan 2008, 9:49 am | #4 |
Getting nitric acid might be a bit difficult! Clock cleaning fluid (google for Horolene or a clock material dealer like M&P or A G Thomas). This contains ammonia, detergent and oleic acid. It will brighten brass in an hour or two, but you will probably need to lacquer it afterwards.
Both vinegar (acetic acid) or lemon juice (citric acid) will brighten brass to some extent. The matt brass finish you see on plug pins and the like is produced by a wash in nitric acid, then water, then chromic acid. All these are only for a few seconds.
Mike. |
20th Jan 2008, 10:31 am | #5 |
The brass grills on Marconiphone and HMV sets were generally given an aged look to tone down the brightness. This was achieved by a coating of slightly toned cellulose lacquer.
I don't know the T14A specifically as I am mainly interested in pre-war sets, but I guess it would have had the same treatment. Keith |
20th Jan 2008, 12:01 pm | #6 |
I have come across "Quiksilver" at antique fairs and it certainly seems to work. However, I have also heard that crumpled up aluminium foil in the same solution works just as well! (but not tested).
Regards, Richard, BVWS member |
20th Jan 2008, 3:22 pm | #7 |
Interesting, Richard, as washing soda (sodium carbonate) will do that as well. I have seen magic silver brighteners consisting of a sheet of aluminium with fancy holes in it being sold for ££s and demonstrated by sellers with a few tarnished silver spoons in a bowl of washing soda!
Mike. |
21st Jan 2008, 9:38 am | #8 |
I did somthing like this using tin foil many years ago to clean up a silver condement holder I found in a stream which was really crusty . it worked very well . fizzed away .and at the end there wasnt much left of the tin foil !
29th Feb 2008, 10:21 pm | #9 |
Many thanks for your replies. I eventually gave up trying to clean the brass grille and sprayed it with 3 very light coats of Plasikote brass spray paint. The grille now looks as good as I would imagine it looked 60 years ago.
29th Feb 2008, 10:44 pm | #10 |
Among the model engineering guys, one of the "standard" cleaners for brass, bronze, and copper, is a saturated mix of salt and vinegar. Works well.
11th Mar 2008, 10:36 am | #11 |
Hello,
I restore a lot of brass trim. Almost all the brass I've encountered was originally lacquered but the lacquer has expired so tarnish has formed on the brass underneath it. Once the old lacquer has been removed using Nitromors or a solution of vinegar, hot water and washing up detergent, polishing the brass is easy, I just use Brasso. I always relacquer polished brass with Rustins cold metal varnish sometimes mixed with M&P dark gold lacquer to darken it slightly. I will try the quicksilver solution though cos vinegar takes a while to work. Howard |
29th Mar 2008, 10:46 pm | #12 |
Raw brass like fixings, nuts, pillars etc; Cillit Bang works a treat.
Geof |
